What brand of lower control arm mount to replace stock
rmonte4812
Chandler AZ
Looking for a recommendation on replacement lower control arm mounts. I've seen some that use cam bolts and some that are just a straight through bolt. The cam sounds nice for adjusting but I would this it would get out of whack on the first trail. Any suggestions?
The cams are for the TJ's that don't have the adjustment in the frame mount, stick with the stock type. You can get these just about everywhere nowadays and there pretty much all the same, I got mine from Rustys. Just make sure whatever you get they are 1/4".
Clayton pro-series. They don't hang below the axle. You need to be able to shorten your LCA's an inch or so(adjustable).
