Old September 23rd, 2011, 17:38
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Re: Everything you ever wanted to know about the AW4
The plug for the 4wd indicator is actually on the transfer case, not the transmission. Let me see if I can find out how you're missing the plug for that... my bet is that the cable and plug got tangled up behind/on top of the transmission during the swap.
EDIT: Think I figured it out. You probably have two plugs that can plug into that now - one from the harness that also handles the rear O2 sensor and the VSS, which leads to a 10 pin connector up near the connector you spliced for the transmission solenoids and speed sensor (this is the plug you want) and the other that's built into the harness that came with the 96 AW4 (which goes nowhere, and is the extra wires you mentioned when asking about the butt splices.) Not sure how I missed that in the writeup, especially since I used to own a 96. Try the plug that's on the harness going to the VSS and O2 sensor, it might be hidden up behind the transfer case or transmission after the swap.
I'll update the first post, thanks!
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old December 13th, 2011, 17:06
aquickmopar's Avatar
aquickmopar aquickmopar is offline
Alright I just wanted to start out saying thanx for all the great information on the AW4.
Now my question is I have a 96 Cherokee Classic with a AX-15 And it is going down hill fast needs replaced. I also have a 89 Cherokee Laredo as a parts jeep. With a good working AW4 With the power/comfort switch. I read were it will bolt up and can be used. What im asking is what all do I need to pull out of the parts jeep besides the AW4 Tranny, wireharness, Power/comfort switch, TCU, and swapping the input shafts on the transfercase or just swapping the tranfercase altogether? Do I need any thing else? Does the TCU get wired to ECU in anyway? Or do I need to splice into anything? Or is it just all plug and play and no splicing? Any help will be greatly appreciated.
Thanx,
Old December 13th, 2011, 17:22
kastein's Avatar
Since 89 to 96 swaps across the 94.5 line for the transfer case input gear helical pitch *and* the 95 to 96 transfer case tailcone seal style change, you're going to have to swap in the AW4, transfer case, AND rear driveshaft... but AX15 vs AW4 have different driveshafts, so you're going to need to find an 87-95 4.0/auto/4wd rear driveshaft from a donor with the same rearend as you, and a front driveshaft from any 4.0/auto donor. I really wouldn't do this swap, it's opening a pretty big can of worms mechanically. You will also need the transmission crossmember and AW4 shifter + cables from the donor, possibly a TV kickdown cable from a 91-01 AW4 (not sure if the RENIX style TV cable connects to the throttle body on a 91+ the same way or not), and I'm sure I'm forgetting some other stuff. Oh yeah, trans cooler hoses as well.
The electronics are going to be interesting, you will want to find a 91-96 TCU and wire it in, since your TPS is the OBD style the 89 one may or may not work. It will involve a lot of splicing since your harness doesn't have any of the connectors for the TCU, might be missing contacts in the brake light switch, doesn't have the wiring for the TPS to TCU connection, the NSS, the trans sensor+solenoid harness, etc.
If you can find a 91-96 donor with 4.0/auto/4wd/same rearend as you, the swap will be much easier (you'll need trans, transfercase, driveshafts, and support parts for the trans), but will still involve a decent amount of wire splicing.
I would really just try and beg/borrow/trade another AX15 off someone, or rebuild yours. What's wrong with it? If it is just the synchros you can get all the ones you need off quadratec for around 100 dollars and maybe throw in some bearings for another hundred or so. I haven't ever rebuilt an AX15 but am hoping to pick up a spare to rebuild soon.
Old December 13th, 2011, 17:26
oldcancer's Avatar
oldcancer oldcancer is offline
i'm curious, if i don't have the power/granny switch from factory, would the transmission just be defaulted to granny mode? also, would i simply be able to add the option by finding the pigtail behind the dash and adding the switch? or perhaps bypassing it, like i saw mentioned in here before?
1994 XJ
Old December 13th, 2011, 17:29
kastein's Avatar
I'm not sure if a 94 even has a place to plug the switch into the harness, and pretty sure the TCU is blissfully unaware of the feature ever existing. You'd need to swap in an earlier TCU that supports it and wire the switch to the proper pin.
All I ever did with my power/comfort switch was bump it into comfort mode by accident with my knee while 300 miles from home and panic, thinking my 200k+ mile AW4 had just started dying.
Old December 13th, 2011, 17:35
oldcancer's Avatar
oh i see, doesn't really sound like something worth doing if there are no really notable performance gains other than feeling a slightly harder shift
i'm not really sure of the pros/cons of power vs comfort right now anyways so i don't see all that wiring to be all that beneficial at this point
Old December 13th, 2011, 17:36
Hey thanks for the fast reply, I believe my synchros are gone. Can Hardly ever get it in and out of gear, and the only way to get it into reverse is I have to shut off the engine put it in reverse and then start it back up. Plus another reason for wanting to swap in the AW4 Is that I HATE trying to wheel with a 5-speed just constantly on the clutch and gas and break all at the same time pretty much trying to crawl over rocks is not fun. I was hoping it wouldn't be all that hard to swap over since I have all the parts in the Donor Cherokee. The transfercase in the donor Cherokee has a slip yoke eliminator already on and has a rear tom woods driveshaft if that helps any. I really didn't want to have to go and buy another transmission from a earlier year at the junk yard since I already have a good one in my parts jeep.
Old December 13th, 2011, 17:38
cruiser54's Avatar
cruiser54 cruiser54 is offline
What you're describing with the manual trans does not sound like synchros. It sounds like incomplete clutch disengagement possibly caused by faulty clutch hydraulics.
Old December 13th, 2011, 17:43
oldcancer's Avatar
i would imagine so too, perhaps due to excessive clutch use required while crawling rocks, it would wear the system much more quickly?
Old December 13th, 2011, 17:44
The Master and slave cylinder have both been replaced and hydraulic lines bled. I figured synchro's were going bad.
Old December 13th, 2011, 17:45
cruiser54's Avatar
I'll bet the clutch is toast then.
oldcancer's Avatar
^^^AHH ya beat meh
don't quote me on this, but perhaps it could be due to excessive wear on the clutch disc and flexplate?
Old December 13th, 2011, 17:46
cruiser54's Avatar
Ya gotta be quick!!!
Old December 13th, 2011, 17:48
oldcancer's Avatar
im just guessing on most of this anyways, i just put a clutch master/slave and a new clutch in an old yj we have at work designated "the mule" we use it for hauling, and man was that old clutch ever soft
intermittently it would also not go into any gear, unless of course it was "coaxed" in
Old December 13th, 2011, 17:49
Clutch feels fine no slipping at all. Just has problems getting in and out of gear.
Wanted Phil Sierra Chapter For Sale 2 October 21st, 2008 08:58
Wanted: XJ MrWonderful NAC Classifieds 7 October 5th, 2006 15:31
WANTED-ECM 90MJ242 NAC Classifieds 5 September 23rd, 2006 12:26
98-99 HP D30 wanted Talyn Wanted: Private Party Only 1 July 14th, 2004 20:57
