Old October 18th, 2018, 12:26
BCKNBLK's Avatar
BCKNBLK BCKNBLK is offline
Check Engine light operation
So, on my '01 XJ 4L, I went to get an emissions check a few days ago and it failed due to an intermittent misfire. It was throwing codes for all three ignition coils. No problem, I changed the ignition coil bar yesterday, erased the trouble codes this morning, and took it for a long drive before heading to the emissions station again. Before it was even tested, the operator there said that it was not going to pass the test because when he turned the key/ignition switch to the 'On' position (no start), all the other test lights on the dash came on initially except for the check engine light. So how does this work? I thought that by driving the vehicle around for a while with the new coil bar, the computer would reset everything it needed to. I cannot imagine the light bulb back there burned out. What do I need to do to make this work right, now that I've changed out the coils and I need to get it tested?
Thanks!
Old October 18th, 2018, 13:18
md21722 md21722 is offline
Re: Check Engine light operation
If the light does not cycle on and off when you start it, then it probably burnt out and you need to pull the gauge cluster and change the bulb.
Old October 18th, 2018, 14:21
RCP Phx RCP Phx is offline
You also need to check whether it's completely ready(PCM). Here you can have 2 "not-ready" but no more.
97 XJ engine RPM increase in conjunction with check engine light. Craigabooey OEM Tech Discussion 6 August 26th, 2010 08:13
guages die when airbag light comes on, wtf? check engine light on rockhard4x4 OEM Tech Discussion 9 June 20th, 2009 06:34
Check Engine Light (the amber motor light) rjstiles OEM Tech Discussion 8 June 3rd, 2009 10:36
OBDII Engine Code Reader - Check Engine Light Diagnostic - NEW BigTP2 For Sale: Private Party Only. XJ ITEMS ONLY 1 December 19th, 2006 12:00
How to check readings from check engine light Brad Klammer OEM Tech Discussion 2 October 11th, 2006 19:55
