Dyno results.......
RCP Phx
Phoenix,Az
The last pull was 2-1/2 yrs ago(325HP/395 TQ), since then I reprogrammed the PCM, installed #27 injectors, added 1.7 rockers(which net about .500" lift), and a MSD with a Screamin Demon coil. I only gained about 5hp on the top but I gained majorly in the torque/horsepower about 20hp right off the bottom all the way to almost the top.
They were unable to print anything today, so all we were comparing it to was my original runs.
I just got off the phone with Russ, since he is now a Holley/MSD distributor he's been wanting updates on how this is progressing.
I should add that I gained another usable 500 rpm also.
Interesting. I wonder how much more you would benefit with a bigger cam
We talked about the new cam Russ is using but the decision was made not to pull the motor back down so instead the 1.7's came into the conversation. The net results are about the same as his new cam.
