OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Minimum tire pressures
Hey guys,
Curious what minimum tire pressure is safe for some 31" Duratracs on the original 5-spokes? We got stuck in some snow the other day and I aired down to 15psi just to get unstuck. Thought I could perhaps have gone down to maybe 10, but did not want to risk a de-bead. What are your thoughts? Thanks! |
#2
Re: Minimum tire pressures
There are tire calculators that take into account the vehicle weight, rim diameter, and the tire width in addition to diameter of the tire.
For me 33x12.5 Wrangler MT tires on 15 inch rims I will go to 12 psi (warm tire) on moderate trails, but my calculator says it can be as low as 9 psi.(cold tire) For you, what width tire, what diameter rim, what weight? Off the top of my head 10 psi might be at the lower limit as generally smaller tires need more minimum pressure, larger dia rims also need higher pressure than smaller rims. https://parksoffroad.com/prodreview/...asis/oasis.htm the link shows the calculator I have, thats were I got my data. I also have the Oasis auto deflators, which are really well worth it. |
#3
ps sure you can go lower than the calculator, but then the risk of tire coming off the rim may increase.
#4
I've been running 12 in front with 10 in the rear forever.
#5
Tire Diameter: 31" Wheel Width: 7" Wheel Diameter: 15" Curb Weight: 3,357 lb |
#6
I'm running 265/75/16 Duratrac's.
#7
Well, so far seems like 12psi might be a smart limit based on what I'm reading here.
#8
9 psi at 3000 lbs weight, 10 psi at 4000 lbs. Speed shall be limited to 20 mph, add 3 psi for each 10 mph over 20 mph. |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Street tire pressures | 1911Shooter | Modified Tech Discussion | 18 | March 27th, 2009 10:15 |
MINIMUM tire size for a D60? | hot_rod_hooligans | Modified Tech Discussion | 25 | December 24th, 2007 15:13 |
tire pressures- anyone use this formula? | fordtech | OEM Tech Discussion | 19 | April 18th, 2007 13:36 |
Tire pressures for Mud Terrains | softwiz | Tow Rigs and Trailers | 9 | November 11th, 2005 12:33 |
Tire Pressures | Rocketman | OEM Tech Discussion | 4 | March 31st, 2005 18:19 |
