- Westminster, SoCal
OK, here's an odd one. I've been somewhat reliably getting 15~16 mpg and then suddendly yesterday it dropped to about 12 (over 120 miles of same route as before). Today same thing. Only thing that I did was on Sunday I dropped a can of chevron fuel injector cleaner into the tank (I do that once every few months). Thing is that since I do that every so often I know what to expect: I usually loose about .5 mpg for the first half tank after using it (I fill up @ half tank) but then it goes back to normal. Scary thing is that it dropped more and it didn't recover. What is it? What should I check? I looked at my RPM's and they are nice and even. The engine sounds the same as it did before (for the most part if something changes in the way it runs I can hear it).
XJ has about 150K miles on it (not really sure as it's had the cluster swapped twice and it shows now 107K ).
