Old January 6th, 2019, 16:07
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
synthetic winch line brake heat protection
Iím posting this in the XJ modified tech section because I canít find a better place, but itís really not XJ-specific.
Itís about time I upgrade to a synthetic winch line and ditch the heavy and dangerous steel cable thatís spooled up on my Warn m8000 winch. I understand that a synthetic line needs protection from heat generated by the winch brake mechanism. Some of the lines Iíve been looking at come with thermal insulation for the first wrap, but the insulation only covers the first five feet of line. I havenít measured, but my strong sense is that the first wrap will use more than five feet of line, leaving some of the line in direct contact with the drum. Will this be a problem? Or can I expect that heat from the brake will not travel the whole length of the drum?
Any insight or advice would be appreciated.
Old January 6th, 2019, 20:30
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: synthetic winch line brake heat protection
I have never worried about the heat, and my existing line (which is WARN, BTW) does not have any heat protection.
In the past I have used both Masterpull and Viking winchlines with a heat shield. Both lines had enough protection to more than cover the first wrap.
I do suggest going up to a 3/8 line.
Old January 6th, 2019, 20:49
Weasel's Avatar
Weasel Weasel is offline
Only time you really heat the drum is when you spool out, or what I was told. Most use the free spool for long out and winching out is only done for short durations.
Due to the location of mine on the crawler I don't have a free spool option and power in and out, not had a problem and I'm running a really old X-line from ORW.
Just add lightness
Old January 6th, 2019, 23:48
Nimrod's Avatar
Degenerate Jeeper
Good info. Thanks, guys.
Old January 7th, 2019, 11:57
Trouble Trouble is offline
you generally see the most heat increase when powering out. Ive measured a 76įF change. for a final temp of 164į. syn ropes will start to deteriorate at 140į. Strength will also rapidly decrease at that temp. There are several companies that sell heat guards for rope, so even kevlar braided.
some of the new ropes will have a heat/uv/chafe resistant outer covering. technora is frequently the cover over the dyneema rope, then coupled with a poly or kevlar heat shied for the best performance.
also there are some ropes that are starting to use a higher resin content along with a tighter weave for better chafe protection and strength.
fyi when tested the warn 3/8" spydura pro broke at 23500 lb.
Old January 10th, 2019, 08:19
LLLux31 LLLux31 is offline
I'm running an UltRanger 3/8" synthetic cable on my X20 winch and never had any issues with heat damaging the rope. The rope is double layered though so maybe that keeps it protected. Going on 2 years with the same rope.
Old January 10th, 2019, 10:57
Nimrod's Avatar
Degenerate Jeeper
Good info from everyone. Since I don’t anticipate ever needing to power out more than a couple inches just to slack the line, I’m not going to worry too much about heat protection.
Old January 11th, 2019, 10:03
XpedientJ's Avatar
XpedientJ XpedientJ is offline
The Superwinch, or at least the Talon series, does not have the brake in the drum, but in an end, so no issue of heat build-up on the drum in power-out mode...
Not pertinent to the OP's issue/consideration, but thought I'd mention. Otherwise, yes, I would think, as per recommendations, the protective sleeve is a good idea.
Old January 11th, 2019, 12:02
if its the new x20 with wireless remote, the brake is mounted on the motor and will not create any heat that would significantly effect the drum temps. during testing of that winch i only saw a 2-3į temp increase over the 10 min test. There are a few other winches with a out-of-drum brake , they also tend to freespool with little to no drag.
one word of advise, stay away from the off brand winch ropes you find for incredibility cheap. Many of the amazon special of sub $200 ropes ive tested fail below 12k and many are severely over rated. ive seen 3/8" ropes fail any where from 12k-21k during testing.
Old January 11th, 2019, 12:05
Yeah it's the newer version. Good to know.
I've got 40-50 pulls on this line so far with one being a crew cab f350 from a lake with a blown motor.
I wouldn't recommend it if it was garbage but I agree there are a loy of crappy synth lines on amazon/ebay.
Sent from my SM-N910V using Tapatalk
synthetic winch line souske SoCal Chapter 14 January 29th, 2015 08:57
synthetic winch line Rob707 Sierra Chapter For Sale 3 April 7th, 2014 17:14
Heat and synthetic winch line Rod Knee Modified Tech Discussion 5 November 23rd, 2009 00:05
WTB: synthetic winch line BOB Wanted: Private Party Only 0 October 19th, 2007 15:45
synthetic winch line mounting on winch? Jeff 98XJ WI Modified Tech Discussion 3 July 27th, 2003 20:28
