Old April 4th, 2004, 18:47
Safari Ary's Avatar
Safari Ary Safari Ary is offline
Chevy TRE taper same as Ford TRE taper??
Just about finished aquiring parts for the 50 and putting them together. Last couple things I gotta do are steering related. I want to use the Blazer TREs that have the hole in one of 'em for the draglink to go to(originally intended for a steering stabilizer mount). What I need to know is if these will bolt into my ford F-150 knuckles(late 70's vintage) or if I'll need to modify them in some way. Thanks
Ary
Old April 4th, 2004, 19:13
old_man's Avatar
old_man old_man is offline
Re: Chevy TRE taper same as Ford TRE taper??
First off, that TRE you are talking about has a very small tapered hole. Thats a good thing because if you want to mount your draglink on the front of the TRE, it is tapered the wrong way. You will have to ream out the hole to fit any standard type TRE. I know because I am using that on my HP D44 build. The reamers run from $40 to $80 depending on where you get it. I wish I could find one to borrow/rent local in Colorado, otherwise I guess I'm going to have to fork over the $$$. LOL
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old April 4th, 2004, 19:35
Safari Ary's Avatar
I know I'll have to ream the hole in the TRE to fit the DLE. I'm talking about the taper in the knuckles. Can I use Chevy TREs in Ford knuckles without reaming the knuckles?? Thanks
Ary
Old April 4th, 2004, 20:51
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
Ary
All I know is that the Chevy 1 ton TREs have a 7 Degree taper. I don't know about the Ford ones.
Billy
Old April 5th, 2004, 11:25
Safari Ary's Avatar
Anybody??
Old April 5th, 2004, 12:13
CRASH's Avatar
CRASH CRASH is offline
The taper is the same, the holes are sized differently, though. You'll have to ream the Ford holes a bit larger to accept the Chevy TRE.
CRASH
Old April 5th, 2004, 14:15
Safari Ary's Avatar
CRASH
Thanks
Old April 5th, 2004, 15:03
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
I'll rent you mine for $20 a day plus shipping from Yewtaaw.....
Speak the Truth-Question with Boldness
Old April 5th, 2004, 15:04
XJEEPER's Avatar
NAXJA Member # 13
Old April 5th, 2004, 18:11
old_man's Avatar
Seeing as how I can buy one for $40-60, I think I'll pass. Or maybe I'll buy one and go into business.
Chevy NP203 Range Box & Ford NP205 T-Cases Israel For Sale: Private Party Only. XJ ITEMS ONLY 2 March 24th, 2004 10:26
Chevy 350, very low miles 4 bolt main mountaindrew For Sale: Private Party Only. XJ ITEMS ONLY 4 December 16th, 2003 09:06
what's the # on the TRE with 3/4-16 and XJ taper? BrettM Modified Tech Discussion 1 November 26th, 2003 13:11
32 spline Chevy 241 and a divorced Ford 205 TPI MJ Wanted: Private Party Only 0 July 7th, 2003 22:39
