Old June 30th, 2020, 07:59
XJ_4LOW XJ_4LOW is offline
Fuel Tank Fab Question
Hi All -
I'm fabricating an aluminum fuel tank for my '96 after fabricating a 4-linked ford 8.8. The only aluminum fuel pump ring I can find is from GenRight (https://genright.com/products/fuel-p...004-tj-xj.html) and requires a swap to the '97+ fuel pump.
Has anyone swapped a 97+ pump assy into a 96? I think the '96 pump assy includes the pressure regulator, and I'd have to put on an external regulator from a 97+ as part of the swap.
I'm not sure how to make this work, and am hoping someone has swapped the GenRight 35 gallon tank into a '96 or earlier XJ and can share some tips on making things work (Fuel pump assy, fuel level gauge, correct pressure, etc).
Thanks!
Old June 30th, 2020, 08:40
RCP Phx RCP Phx is offline
Re: Fuel Tank Fab Question
It's the other way around, the newer pump has the pressure regulator built into the pump and does not utilize a return line. It does operate at a higher pressure though, that "could" be a issue with your injectors.
Old June 30th, 2020, 11:43
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
e2000 fuel pump FTW.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Fuel tank question tjmotter OEM Tech Discussion 34 August 13th, 2016 15:59
Fuel Tank/Fuel Pump Question ddeadserious OEM Tech Discussion 4 June 18th, 2008 19:35
replacing fuel tank o-ring - other methods to solve fuel tank leak rickoregon OEM Tech Discussion 3 February 21st, 2007 13:33
Fuel tank question Motornoggin OEM Tech Discussion 2 June 27th, 2005 20:56
HELP YJ question, BBD and fuel tank RichP Tow Rigs and Trailers 2 July 17th, 2003 10:33
