Old June 23rd, 2020, 18:00
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Disc swap?
I swapped to discs finally, but I didn't swap proportioning valves because I wanted to see how it feels.
I can say there is more pedal travel. I bled the brakes with a bottle and had solid fluid when I closed them. Ive always done this method with great success, i just need to know its not air in the line. Is this likely due to the prop valve?
Also how much drag is recommended on the e brake? Currently it's immediate on the handle, but wheels spin 1.5x freely. These don't self adjust do I need to get it right.
Old June 23rd, 2020, 18:49
RCP Phx RCP Phx is offline
Re: Disc swap?
The travel loss is due to the volume the rear calipers consume. As far as the E-brake I have not had any luck with a adjustment that I like and am comfortable with.
Old June 23rd, 2020, 20:31
Re: Disc swap?
Did you switch your prop valve?
Has anyone tried both and can you say there's a difference?
Old June 23rd, 2020, 20:46
KarmaKannon KarmaKannon is offline
Re: Disc swap?
I had an 8.8 with disc brakes on my last xj and the brakes felt pretty good. They were better than it ever was with the d44 and drums. I didn't do the prop valve, but I like a little rear brake bias anyway. It's always nice to be able to steer if you need to slide.
Old June 23rd, 2020, 21:33
Re: Disc swap?
well as RCP says do to the rear calipers, im just trying to get a feel for how these should behave.
I beaded the pads and got a feel for the pedal travel compared to stock. I expected different, but I was quite surprised that the pedal now goes so far in travel. I dont know if its better, but it is different. It would be nice to know the brakes could lock up if I wanted, not happening lol.
If there was air the pedal would just drop to the floor effortlessly right?
Old June 23rd, 2020, 21:38
Re: Disc swap?
bedded*(EDIT) why did naxja like the idea of removing this feature, oh well.
Old June 24th, 2020, 03:32
Re: Disc swap?
Probably the same sound reasoning that concluded the Utah regional chapter should be the part of the Colorado chapter.
So you can't lock up any of your tires (front/rear)? What size tires are you running?
Old June 24th, 2020, 07:00
Re: Disc swap?
I'm still running my stock proportioning valve but I moved up to a Durango master cylinder. Understand that I also did WJ fronts so that eats up even more pedal.
https://naxja.org/forum/showthread.php?t=1134835
Old June 24th, 2020, 07:10
Re: Disc swap?
99 on 35s, no they arent even close to locking up currently. I had a better shot with drums which I find odd.
Old June 24th, 2020, 07:20
Re: Disc swap?
My 8.25 had a lot of end play affecting my pedal travel so I also shimmed it.
https://naxja.org/forum/showthread.php?t=1149274
Old June 24th, 2020, 08:30
Re: Disc swap?
BTW, you have a "parking brake" which is meant to keep a "stopped" vehicle from "rolling". What did you do for cables?
Old June 24th, 2020, 08:41
Re: Disc swap?
https://www.morris4x4center.com/roug...-5-dbc-06.html these, i think its the same cable a few companys slap their name on.
Old June 24th, 2020, 08:46
Re: Disc swap?
you shimmed the c clips or added a washer to the caliper mounting plate?
Old June 24th, 2020, 09:09
Re: Disc swap?
I shimmed under my c-clip(s).
Old June 24th, 2020, 09:31
Re: Disc swap?
any pictures of this, im not getting what youve added. I remember your thread on this, but how does this shim stay in with the c clip?
C8.25 disc swap ?s 4x4JeePmaNthINg Modified Tech Discussion 55 June 27th, 2019 01:10
Disc swap and ABS? DanMan2k06 Modified Tech Discussion 2 December 5th, 2012 12:19
xj d44 with zj disc swap nismo5 Sierra Chapter For Sale 0 July 7th, 2010 18:34
ZJ disc swap, now DW. Help? yossarian19 Modified Tech Discussion 0 October 19th, 2008 18:48
zj disc swap toplessxj89 Modified Tech Discussion 14 August 26th, 2008 15:15
