Old June 28th, 2020, 11:30
Evan03 Evan03 is offline
Oil pan gasket was leaking easy job right now
Old June 28th, 2020, 12:20
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Re: My jeep build with photos over the last few years.
Def do the rear main while you have the pan out... Cheap and have to drop the pan to get to it- and likely to leak one day if its not now
97 XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old June 28th, 2020, 18:35
Thanks for the tip. Just now finished rear main and pilot bearing
Old June 29th, 2020, 16:01
In hindsight I see I sound like captain obvious there... but didn’t see you mention it, and who knows who references it down the line... google pulls some crazy stuff out of the air some times... so for the next guy
Old June 29th, 2020, 18:16
I actually wasn't going to do it. For Rcp shake I figured I better do it right. I dont want to get kicked out of the club
So I cleaned and prepped sprayed the pan Miller welder blue. Then cleared it today. Uggggh guess I'll do it over.
Clear is eating it off
Old June 29th, 2020, 19:32
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
what clear did you use?
all is not lost if you let it fully cure and sand down the high spots, or you could hit it with another color from an angle, then sand it to get some neat two tone look.
Old June 29th, 2020, 19:37
Cheap stuff. Rustoleum or something maybe the blue is krylon. I guess the dont go well together.
It does seem to be hardening now
Old July 1st, 2020, 21:13
Evenings progress .
Tomorrow pilot bearing and clutch
Old July 2nd, 2020, 06:21
Anak's Avatar
Anak Anak is offline
Stranger
Nice and purty.
That should show the oil leaks really well. (Knowing how Jeeps work)
Baby it's cold outside.
Old July 3rd, 2020, 06:44
Ohhhyeah.
Picked up gaskets for oil filter adapter nee an gasket nd rear main. Last leak on the list is power steering box.
Sitting in the chair looking at jeep.
Thinking about ordering 4.56 gears for dana 30 nd 8.25.
Will have good tranny mise well make use of all 5 gears. I'll hve to recruit help to do gears I'm absolutely dont like asking for help
Old July 5th, 2020, 18:56
So we spent some time fishing and soaking up some sun Ray's on the river and lake this weekend. Missing have the jeep to go on trips in, but man I gota say the pickup is nice. I've pulled welder and tools out of it. Just nice
This is the snake river in Idaho one of my favorite secret fishing spots. One of those places you hope the small ones get of before you get reeled in.
Did manage to get flywheel bolted on bolts cleaned and locktighted with red. I tourqed to 90 since I decided to reuse the old ones.
I'm debating on going out right now and bolting clutch on and stuffing tranny. Kinda thinking i might bolt tcase to tranny and stuff them together. The tcase shift lever pivot point bracket bolt is a pain to get to while in there.
There may be random photo of magnaflow xl muffler in here. More on that later maybe
This years build plans KRAKER Arizona Chapter 40 January 15th, 2012 20:01
Ballistic build - a few years old, still cool video! BallisticDave Vendor Advertisements 3 October 11th, 2011 23:15
best years for a build? MahnkenVille Modified Tech Discussion 38 November 3rd, 2009 20:36
Merce-Jeep photos Vee Dubb Modified Tech Discussion 36 November 23rd, 2007 16:53
My XJ build in progress. More photos to come... aszaunmi Arizona Chapter 32 February 11th, 2007 10:32
