Old March 15th, 2019, 07:39
CLSegraves CLSegraves is offline
Stiffen Rear Frame?
01 4 door XJ.
I'm looking for a way to stiffen up the rear cargo area/rear hatch area of my XJ.
I was out wheeling last night and stopped on a really flexed spot (I was checking suspension component clearance/etc. after making changes). I opened the rear hatch to get something and then couldn't get the rear hatch to close correctly (it latched fine after I got back on flatter ground).
Now yes, the simple answer is "don't open the rear hatch when the body is flexed out" but I'm taking this "issue" as an indicator that the rear of the body is twisting and that's something I'd like to prevent (less twist = longer lasting body).
I've already done 3/16" welded frame stiffeners from front to back. I'm thinking of welding a piece of 3/16" plate on the back side (fuel tank side) of the rear crossmember (where the bumper bolts onto). If anyone else has some suggestions/experience in stiffening the cargo area, I'd appreciate the insight. I'm trying to avoid a cage as it's also a daily driver and I don't want to loose the versatility.
Old March 15th, 2019, 07:59
RCP Phx RCP Phx is offline
Re: Stiffen Rear Frame?
Get a bumper that utilizes frame mounting points. My 2k does not flex in the back or front do to the bumpers.
Old March 15th, 2019, 08:24
denverd1 denverd1 is offline
I believe you also need some reinforcement between the bumpers as well. If for nothing else than to protect leaf spring hangers, steering gear mount and control arm mounts. although I have both front and rear bumpers and have beat on mine pretty hard with no signs of cracking or damaging the areas I mentioned. I just don't believe the stock unibody can hold up to the type of abuse I give it. YMMV. A good crossmember helps as well.
FWIW I have stiffeners running from firewall to front bumper. the mid section stiffeners are in my garage waiting on a sunny saturday to get installed and I'm installing rear shackle relocators and will try to box in or plate anything that looks weak.
I'm finally getting my rig built where I want it, definitely don't want a crack in the unibody that I need to fix or compromise it's structure. cheap insurance I guess.
Old March 15th, 2019, 08:28
Any pictures of your bumper?
I currently have a JCR 3/16" plate bumper that mounts to the factory bumper location (the 8 bolts on the rear crossmember).
Old March 15th, 2019, 08:30
I already have (and are installed) 3/16" welded frame stiffeners (front, mid and rear). I'm trying to prevent the body from twisting now.
Old March 15th, 2019, 09:31
Here is on of the rears I built for my Cheromanche.
Old March 15th, 2019, 09:48
Here's the front I built for same Jeep.
Old March 15th, 2019, 10:18
Rock rails are important part of the combination. I built these for the same rig that ties into the leaf spring pockets and the roll bar.
Old March 15th, 2019, 10:25
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
The Cherokee is called a boneless Jeep for reason, and the unibody flex is not an issue until you are really abusing it.
Tie the ends of the frame rails together with bumper mounts that incorporate the frame rails, or bolt on a Class-III hitch. Reinforcing the rear crossmember might be a good idea also.
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old March 15th, 2019, 19:13
Anak's Avatar
Anak Anak is offline
Stranger
JCR's gas tank skid with its flange running across the rear of the body looks like it might be helpful here.
Stiffen Leafsprings without more lift. xCWolf Modified Tech Discussion 6 September 7th, 2017 11:20
plating rear of frame vs. rear bumper dfarmxj Modified Tech Discussion 13 February 13th, 2013 15:27
To stiffen or not to stiffen?!? jeepxj2007 Modified Tech Discussion 23 February 1st, 2011 19:13
Rear Frame Killer95_XJ Paint and Bodywork forum 5 April 6th, 2009 16:26
rear frame stace Advanced Fabrication and Engineering 4 February 4th, 2007 07:41
