dallas xjs
- dallas tx
97 cherokee auto trans\
started friday trouble shooting why my jeep would not start..well after searching forums came up with the neutral safety swicth...so tried starting between gears..it would now start between n ad r...so now all i need to do is just jump #30 on the starter relay...well from the happiness of knowing my jeep starts now i ended up jumping #30 on the fuel pump relay...now all gauges on the panel cluster wont move and the engine start dummy light does not come on...which it didnt come on before i jumped the relay...the fan also comes on once the key is turned over..now betwenn n and r the jeep just keeps cranking it doesnt start now at all...i have checked all fuses and they are all good..i disconnected the battery for a couple of hours and this had no change..what might of blown by jumping that #30 relay on the fuel pump...i did check voltage at thet #30 and there is no voltage...i checked the #30 on the starter relay and there is voltage..12.4volts...so know iam not sure jumping that would let the jeep start in park by bypassing the nss>>>please help....if i can get in the right direction i know i can fix this....
