Donor 16"x~8" wheel with 5 on 5.5" pattern?
Root Moose
ON, Canada
Anyone know of a junk yard donor for steel 16x8 wheels that have a 5 on 5.5" bolt pattern? 16x7.5 would be fine too.
Looking for cheap wheels with the same pattern that I can put on my tent trailer to match the XJ (my XJ bolt pattern is not stock - this isn't a typo above).
I think this may be an "odd-duck" configuration...
r@m
Dodge Ram -
16x7 kind of ugly IMO.
also ram 16x7 and better looking than the one above.
Hey, thanks for that! That must mean that these trucks came with steel wheels on the lower trim levels too?
Are these Rams half ton or?
r@m
those are both around the 2000 yeart model ram 1500 1/2 ton trucks. they came with steel too but i'm not sure if they are in 16".
matthew
The Dodges has 16's in '96 and I'm guessing about '95 too. One problem though. The center hole is too small to fit over a normall D44 hub. Tried to put the steelies on my old Ford.
