Track bar flag nut
pthompson
mid-Michigan
While trying to replace my track bar I snapped the bolt and had to cut it out. The stub of the cut bolt is still in the old flag nut. I ordered a new set of hardware from the dealer. Now that I am trying to put it back together I realize that the flange is a mirror image of the original. The bends and flange are opposite where they need to be. Has anyone else dealt with this? Trying to figure out if I should press the nut out of each flag and put the new nut in the old flag or rebend the new flag or some third option that would work better. Thanks for any help.
Sent from my SM-G930P using Tapatalk
Have you actually tried it to see if it works?
Flag nuts are for ease of assembly at the factory, they are not required. Does the new flag nut fit/function ? If you straighten and rebend the new one will it fit/function ? The nut is welded to the metal strip you are not going to be able to separate and reassemble them without grinding and welding.
I have used a regular nut and a was able to jam it ( to prevent it from spinning ) a with a punch until the correct torque was reached.
Thanks for the input so far. I have tried it and it doesn't work. The bends being backwards put the nut too far from the bolt. The new nut is definitely pressed in to the flag and held in place with spurs of metal created by scraping the ridges of the nut with a chissle. It could easily be pressed out. The old one looks the same but is so rusted I can't tell for sure.
Get a new bolt and matching flange nut, maybe use some blue threadlocker.
