Old April 10th, 2018, 09:42
Weekender's Avatar
Weekender Weekender is offline
2" lift, Long shackle or Add-a-Leaf?
Considering a little lift for our '01 XJ which is stock, riding on 235/75r15s Wranglers. The most we do off-road are camping trails which may be washed out. No rock-crawling.
Also don't want to get into needing a SYE or other mods but if necessary could go for a Hack-n-Tap and front DS for the rear. But that's more than we're really interested in. This is a DD and son will be driving it to and from college.
So, kits with a 2" front spring spacer and either an AAL or long shackle are plentiful.
Opinions?
This is really more for "looks" than need. The son would like a little more aggressive stance.
Weekender.
Old April 10th, 2018, 10:01
SlowXj SlowXj is offline
Re: 2" lift, Long shackle or Add-a-Leaf?
Maybe just find a spare pack for cheap, and add one leaf to your current pack. Search bastard pack on here. I just did an xj/xj pack for about 3 inches of lift. The stiffer spring rate gave it a better ride in my opinion... Plus if you decide at a later date to go higher then you can add an extended shackle.
Old April 10th, 2018, 11:19
Weekender's Avatar
Thanks. I can find leaf packs in the U-pull-it yard.
Any concern about shock length with a 2" lift? Topping out?
Weekender
Old April 10th, 2018, 11:45
denverd1's Avatar
denverd1 denverd1 is offline
Weekender
they will be the limiting factor in how much downward travel the axle will have, but not entirely necessary to replace them.
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old April 11th, 2018, 06:41
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Use a full length Add-a-Leaf or build a bastard pack. Longer shackles on factory stock leaf springs aggravates sagging. The shocks will likely be fine, if you are highly concerned about the shock length, buy longer shacks, or install bar pin eliminators or shock mount spacers.
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old April 11th, 2018, 08:01
denverd1's Avatar
you could move the shock mounts up in the rear and definitely use the same ones.
Chili Pepper '98
Old April 11th, 2018, 08:13
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I did a 2" lift just by buying new Dorman leafs and running an MJ shackle.
Up front a 2" spacer to match it, was fairly level if not rear high.
Here it is with 30's
Leafs are Dorman 929-301
Coil springs are CC778
Both came from amazon.
Old April 11th, 2018, 10:25
dktool dktool is offline
The Crown Up Country replacement leaf is a good choice, I have used these with and without a full length add a leaf (Iron Rock # 10455) and the hold up well.
With the add a leaf and stock shackles you will likely net a 2" lift over stock ride height, YMMV depending on the current state of your springs.
Old April 11th, 2018, 13:52
Jim Malcolm Jim Malcolm is offline
IMO, the first mod to the rear suspension should be shackle relocators. The shackle angle is crappy on a stock height XJ, let alone when you lift it.
Old April 11th, 2018, 14:23
Yes, first get new leafs and relocate at the same time if possible, post #14 of the following thread shows what I did for a No-Lift re-locator solution.
http://naxja.org/forum/showthread.ph...#post246020217
denverd1's Avatar
^ this. Will net you 2" with extended shackles.
Chili Pepper '98
Old April 11th, 2018, 19:08
smccollamjr smccollamjr is offline
I did Crown leaves with a long RC add a leaf on my ‘96 years ago. It held up well.
Old April 12th, 2018, 06:19
theNAST1EST's Avatar
theNAST1EST theNAST1EST is offline
I just have a hard time recommending time/money spent on suspension mods for aesthetics.
Even if it’s only logging trails and wash-outs, I would get so much more peace of mind knowing that my suspension was “over-done” for my purposes.
My recommendation would be a 3” kit with new springs all the way around (or at very least, new spring packs). It may be more $$ up front, but the kits will not require any drivetrain mods or cause steering issues...not to mention you get the benefit of knowing your rig can get you out of more difficult situations, if need be.
I ran a 4.5” short-arm kit for a decade with extended rear shackles. The TC drop and shims, while not optimal, kept the driveline in great shape.
I hate the saying, “buy once, cry once,” but at some point there’s a lot of truth to it.
Just sayin’...
Old April 12th, 2018, 08:09
Tim_MN's Avatar
My 2000 got a 2 lift, mostly for looks. When I took it to Moab aside from banging on a lot of rocks it did very well. Eventually it got lifted much higher.
My 1999 DD has a 3 inch lift, mostly for looks. I installed an RE 2.5 AAL and an extra stock leaf, both removed from the 00, and a set of Rusty's front coils. I found a set of almost new Bilstein 4600's on a junkyard ZJ, so in total I have $250 in the whole lift.
"custom" leaf Shackle Sherman_thetank Modified Tech Discussion 11 April 13th, 2010 14:31
5.5" Leaf Pack or 3.5" with shackle? TurtleBoyPW5 Modified Tech Discussion 8 November 2nd, 2009 22:21
1" lift shackle bad shackle angle? mitsumotors Modified Tech Discussion 1 April 21st, 2008 20:16
Re 5.5 leaf pack and 1.5 long shackle hit gixer Modified Tech Discussion 9 May 17th, 2007 15:27
Rustys 6.5" leaf pack vs. RE 4.5" with RE 1.25" shackle? XJ99 Modified Tech Discussion 10 January 3rd, 2006 15:17
