ADVNTURR
I worry when rattles stop
- Cleveland, OH
This past weekend when wheeling with one of my friends we got talking about various things and we got on the subject of making rock rails for my 91 4dr XJ. I've been doing some searching and trying to find the best way to make them and attach them and I have a few questions.
My plan is to make the main rails out of 1/4" 2x2 tube, make an angle frame mount bracket out of 3/16" plate and attach it with 2 bolts in the side and 1 or 2 bolts in the bottom of the frame along with a 1x1" square tube bolted to the pinch seam. Here is where the questions start, what should I make arms that go from the frame to the rail out of, I was originally thinking some more of the 2x2", but from looking around I'm seeing some of the aftermarket companies are using thick plate or 1x1", and if I could get away with just the 1x1" it'd save some money and some weight. If I need to add a third frame-to-rail member to use the 1x1" I would be up for trying that. Second question is, what to use for bolts, I was planning on using self tapping bolts into the frame, but how big of a bolt. As for the pinch seam I was just going to use 6 small grade 8 bolts (not self tappers) and I was wondering if I should use 1/4" or 3/8" bolts.
If anyone sees anything I'm overlooking, please let me know. Thanks in advance for the responses.
