Old February 8th, 2007, 13:08
HeavyMetal's Avatar
HeavyMetal HeavyMetal is offline
Oil leak issue, seal identification
so my jeep was just at a garage and its been too cold for me to be fiddling around with my jeep in my driveway doing guesswork, so while they were doing a job i asked em to take a look at my oil leak and lemme know where its originating from. they told me here:
what should i be looking for when i buy a replacement seal and is this as easy as it seems?
thanks gentlemen
Old February 8th, 2007, 13:17
Hamer460's Avatar
Hamer460 Hamer460 is offline
Re: Oil leak issue, seal identification
My 93 was a 15mm hex. I have heard of different bolts like torx and regular head. They are on tight, I used a repalcement bit for a allen hex socket from MAC tools. Then losened with a wrench and cheater bar. O-rings are cheap from dealer under 5 bucks.
Old February 8th, 2007, 13:18
moparmatt's Avatar
moparmatt moparmatt is offline
Three o-rings
http://www.go.jeep-xj.info/HowtoOilAdaptorOrings.htm
Edit: BTW you need a T60 Torx
It is easy to do add like 30mins on top of a regular oil change
Old February 8th, 2007, 13:19
HeavyMetal's Avatar
awesome thanks for the quick replies guys
Old February 8th, 2007, 13:44
Tallpaul54 Tallpaul54 is offline
On my 94 Grand I needed a 9/16 male hex. I used a threaded coupling, worked great. On the 95 XJ it seems to be a 3/8 hex and VERY tight.
Get the o-ring kit from the dealer, much better quality than the after market.
Old February 8th, 2007, 17:38
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
Agreed. Make sure you get the o-ring SET from the dealer, they also sell just the o-ring for the oil filter adaptor, which is the one thats leaking. However there are two other seals on there that you should replace (while you have it out).
What year is your XJ? This will determine if you have a Hex bolt or a Torx. If it's Torx, it's a T60, and be prepared to get creative in figuring out how to get a T60 along with something attached to that to get the damn thing off. If it's a Hex, I believe it's easier, but I don't recall the size socket you'll need at the moment....I know it's on here, do a quick search for oil filter adaptor.
If i'm not mistaken, Renix 4.0's were Hex bolts, and post-renix were Torx. I know mine was a Torx, but I don't remember the cut off year for which one is on what.
Once ya get it fixed, you might wanna degrease the hell out of your motor and clean it up a bit. Looks like that thing's been leakin for a long time. Another sign of the oil filter adaptor seal is oill will be along the bottom and back of the oil filter.
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
Old February 8th, 2007, 18:25
HeavyMetal's Avatar
yeah its been leakin for quite some time
the XJ is a 97. prayin for no torx
Old February 8th, 2007, 19:00
UNCC_99XJ's Avatar
Twisted Up
It's definitely a torx. Sorry dude.... I ended up getting ill with trying to come up with a creative way, and loosened the motor mounts and hoisted the damn engine up just high enough to get some room.
-Timbo -
Old February 8th, 2007, 20:50
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
From the picture, it looks like the distributor to block o'ring is leaking some oil too.
Old February 9th, 2007, 13:37
ratherbcamping's Avatar
ratherbcamping ratherbcamping is offline
Is there an o-ring there? If there is, I had a brain fart, because I don't remember one.
My 99 engine is leaking in the same area. I picked up a set of o-rings for the oil filter adapter from the dealer today (only $4.01), but the oil appears to coming from the distributor. I was going to seal the joint between the block and the distributor with rtv, but if there's an o-ring, I would rather do it right.
Old February 10th, 2007, 09:50
Ecomike's Avatar
NAXJA# 2091
Good question!!!!
There is either an o'ring or at least a flat gasket seal (or maybe both) on my 87 Renix 4.0, so I assume all the 4.0s with distributors are the same. It was the first leak I had to fix on my 87.
I know it has at least a flat gasket seal. I could be wrong about the outer o'ring now that I think about, it has been 2 years since I worked on that problem. I remember mine was missing the gasket for sure now that you mention it. So it may just be a flat gasket seal there, and no o'ring!!!!!
Turns out there is also a seal of some sort inside the distributor shaft / distributor housing / bearing area. If it goes it leaks oil up inside the rotor and cap, YUK. When that one started leaking on mine (the second leak) I finally replaced the entire distributor with a rebuilt one.
Old February 10th, 2007, 09:52
HeavyMetal's Avatar
funny how things come together...so do you think this could be in direct relation to the thread i just made this morning?????
http://www.naxja.org/forum/showthread.php?t=907112
axle seal and leak help cw50must OEM Tech Discussion 7 October 5th, 2006 06:22
2wd aw4 - how to replace seal so that it doesn't leak DeftwillP OEM Tech Discussion 6 March 23rd, 2006 10:28
Output seal leak Zoro OEM Tech Discussion 8 October 21st, 2005 20:16
Oil leak rear transfer seal torfinn OEM Tech Discussion 5 June 2nd, 2004 13:02
Rear main seal oil leak... XJeffro OEM Tech Discussion 7 September 10th, 2003 21:34
