Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old August 11th, 2008, 17:47
sdigs sdigs is offline
Junk yard adventure trailer
I have a chance to buy a trailer cheap. it is made from a 94 dodge dakota short bed and I am thinking about rigging an adventure trailer from it. Does anyone know of any junk yard springs that I could use to make it sit higher? My XJ has an RE 3.5" superflex and rides on 31's. I know nothing about the dakota, what type of rear suspension did it have? any suggestions?
Old August 11th, 2008, 17:50
razdrvr's Avatar
razdrvr razdrvr is offline
Re: Junk yard adventure trailer
you could mate in another dakota pack then see where it sits, add or subtract as needed. Mabye even do a spring over on it.
Old August 11th, 2008, 20:36
DansGreyMj's Avatar
DansGreyMj DansGreyMj is offline
I think dakotas are spring under so you could go SOA with it.
Old August 13th, 2008, 15:09
Chad29860's Avatar
Chad29860 Chad29860 is offline
I say do the spring over and keep stock springs that way it dont ride like .
Old August 13th, 2008, 16:16
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Two things.
First I'd ditch the axle and go with a trailer axle, even a trailer portal style axle. You don't want a diff. hanging down there to get caught. Trailer axles are cheap (under $100).
Second I'd be concerned about width here, a Dakota is as wide if not wider than an XJ and that could be an issue (especially if you're talking about a long bed). The beauty of the M416, M100, and most adventure trailers is that they are pretty short and narrow so when you are making turns the trialer follows the Cheroke exactly.
Just some considerations to make. If you want to be *real* trick you could narrow the bed
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old August 13th, 2008, 16:45
yossarian19's Avatar
yossarian19 yossarian19 is offline
Add a spring from another Dakota pack.
Blazair Blazair is offline
Originally Posted by GSequoia
...I'd ditch the axle and go with a trailer axle, even a trailer portal style axle...
What he said:
Rate This Thread:
Junk yard find................ sprngfldxj Modified Tech Discussion 9 August 10th, 2008 11:04
junk yard GrimmJeeper SoCal Chapter 10 October 8th, 2007 00:11
Junk Yard Help... BigMike80 SoCal Chapter 3 March 15th, 2007 17:15
New to the Junk Yard fscrig75 OEM Tech Discussion 35 March 9th, 2007 09:43
