Old April 24th, 2008, 20:51
obxtuf's Avatar
obxtuf obxtuf is offline
Question looking to do on board air and still have my a/c
I have a high flow york air compressor from work with the serpentine style clutch it was removed from a 9400I international road tractor for warranty recall reasons after 90 days they throw them away and now I have them I (WANT TO KEEP MY A/C) has anyone done this
Old April 24th, 2008, 21:13
jpcherokeekid's Avatar
jpcherokeekid jpcherokeekid is offline
Re: looking to do on board air and still have my a/c
http://www.kilbyenterprises.com/
They have everything you will need.
Old April 24th, 2008, 21:22
jwtrapper's Avatar
jwtrapper jwtrapper is offline
I used a V belt but I still have my a/c. I moved my battery to the back though to make room. You just have to fab up a bracket to mount it and some plumbing parts.
Old April 24th, 2008, 21:52
obxtuf's Avatar
I like the way kilby has done the brackets you can buy the brackets seperate from the kit but they wont work for the serpentine clutch kit so ill fab them up to work. will post pics when I do this. any one want to trade a tank for one of my serpentine air compressors.
Old April 24th, 2008, 21:53
jdxj's Avatar
jdxj jdxj is offline
http://www.madxj.com/
Go to tech then to onboard air
Old April 24th, 2008, 21:54
jwtrapper's Avatar
What kind of tank do you want?
Old April 25th, 2008, 06:00
obxtuf's Avatar
im looking for something that can be mounted under the xj in between the driveline and the framing of the body nothing to big
things I will do in the process 1. the intake line for the compressor will be connected to my air cleaner box 2. I want the single belt setup like how the madxj tech site shows 3. I realize the battery will need to be moved(any suggestions) if I relocate the battery to the trunk that is a hazzard. maybe I could get a gel battery and mount it sideways under the jeep with a protective cover of some type 4. I would like to do this as clean as a factory look
Old April 25th, 2008, 17:01
jdxj's Avatar
Get a cone filter remove the OEM airbox and move the battery to the other side. Thats what I did. The Rustys cone filter adapter is cheap and small. plenty of room for one battery and I'm going to put the second battery over there two. ( I think it'll fit)
Old April 26th, 2008, 20:45
gixer gixer is offline
I would not move the battery to under the truck. With all the dents I have under mine the battery would not last.
Old April 26th, 2008, 23:12
Frank Z Frank Z is offline
http://www.naxja.org/forum/showthread.php?t=951948
Old April 26th, 2008, 23:39
johnnyc's Avatar
johnnyc johnnyc is offline
One thing to note...Kilby does have an XJ-specific bracket, but it is not listed on their website. The part number is KE-1700. I have that kit that includes the alternator pulley, which uses a separate v-belt.
on board air aaronh Modified Tech Discussion 15 April 20th, 2007 11:17
new to the board razrwild North Atlantic Chapter 8 February 8th, 2007 13:43
On board air smallxj Modified Tech Discussion 5 September 8th, 2004 16:42
On board air aueaglexj Modified Tech Discussion 2 September 2nd, 2003 17:11
I like the new Board JHKolb North Atlantic Chapter 14 June 2nd, 2002 07:21
