Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
rear XJ dana 44 axles brands
Im looking to get a set of D44 spares for my XJ D44
Ive have read that TJ D44 axles are a bit shorter but will work but this guy in my club won a set of D44 Superior Rubi axles and he will sell um cheap so basically will Rubi D44 axles work in a XJ D44 I know Ihave to change the retaining plates |
#2
Re: rear XJ dana 44 axles brands
There is no difference. Yes the Rubi rear D44's will bolt right in. cept for the plate.
I've located a drivers side spare Rubi axle. Will this axle work as a spare for my XJ D44 on either side? I vaguely remember reading that one will work for both sides but the opposite side is a tad longer and it will only work on the long side.
Also, this Rubi had ABS so all I need to do is remove the tone ring and swap the retaining plate and I'm good to go, right? Thanks. |
#5
All D44 rear axles are NOT the same length. On the stock D44, even the right and left axles are slightly different. Some people have reported problems because they swapped the R/L and it caused the retainer holding the bearing to move and caused leaks.
#6
One side is 29 3/4 the other is 29 1/4. These are the same as TJ D-44s as in the saraha model.
Check out Yukons catalog (OEM equiv) http://www.randysringandpinion.com/c...sp?vid=1&pid=0 YA D75786-1X YA D75786-2X They call out a different P/N for Rubicon. |
Thread Tools | |
Display Modes | |
Dana 35 Rear Axle MAKE OFFER - 88 xj | TheGirlfriendYJ | For Sale: Private Party Only. XJ ITEMS ONLY | 6 | February 17th, 2005 13:10 |
Early bronco dana 44 swap into a xj | Big Red | Modified Tech Discussion | 9 | September 24th, 2004 17:03 |
87 XJ limited for sale (Dana 44 Rear) | BIG NASTY | South East Chapter | 4 | August 12th, 2004 16:23 |
set of 4:10 dana 30HP and dana 35 non-c-clip XJ axles | rockwerks | For Sale: Private Party Only. XJ ITEMS ONLY | 0 | July 19th, 2004 16:15 |
