Old July 12th, 2003, 19:39
BrettM's Avatar
BrettM BrettM is offline
changed motor mounts -- need part numbers for oil filter o-rings
I changed my motor mounts the other day on my 88 and had to remove the oil filter mount thingy. It is now leaking, and I remember reading on here that it is a good idea to replace the o-rings for the filter mount, and there was part numbers listed, but alas, a search has revealed nothing...
Old July 12th, 2003, 20:50
martin's Avatar
martin martin is offline
From my maintenance records I have the 3 PNs and the price I paid, hope it helps.
33002970 $1.85
33002971 $1.85
33002972 $2.50
I got them at my local dealer 3 years ago, the price may of gone up.
Old July 12th, 2003, 21:52
BrettM's Avatar
awesome! thanks
Old July 12th, 2003, 21:59
cbremer cbremer is offline
NAXJA Member #393
Location: So. Cal. Wine Country 3331'52.15"N, 11708'43.72"W
i went to a local hardware store and got all 3 o-rings for about $1.50 total. just a thought...
Old July 12th, 2003, 22:04
BrettM's Avatar
you wouldn't happen to know the measurements? i really wouldnt' want to take it apart again just to measure...
Old July 13th, 2003, 01:19
NAXJA Member #393
nope sorry i had the oil filter elbow with me and told them "i need o-rings for here, here and here."
Old July 13th, 2003, 17:40
Bones's Avatar
Bones Bones is offline
Be careful of the Mopar stuff. They have a kit of the three rings. Only one of the damn things actually fit my XJ. If you have the thing off the motor make sure to take it with you. I ended up at the local parts house digging through the O-ring selection to get the right ones.
Bones
#6
Old July 13th, 2003, 21:29
martin's Avatar
Bones,
I think the later 4.0 with the horizontal filter use the O-ring kit. For the vertical filter the O-rings come from open stock. Sounds like you had a parts guy assume the kit fit all 4.0 engines when it actually fits only 4.0 engines with the horizontal filter. I may be wrong but think the filter mount changed when the HO 4.0 came out.
I know those part numbers are good, I purchased them and installed them on my 88 XJ with the 4.0. I did not look them up off some internet site.
Martin
Old July 14th, 2003, 02:56
SV1CEC's Avatar
SV1CEC SV1CEC is offline
Does anyone have these part numbers for the old, 4-banger, 2.5 lt engine (carburated, 1984 if that matters).
Tnx
Old July 14th, 2003, 10:36
Erik the Red Erik the Red is offline
Ditto what Bones said. I went through the exact same experience and ended up taking my old O rings into a NAPA shop where the guy matched them from his open stock. He must have felt sorry for me because he didn't charge me for them. So far, the seals work fine and it saved me a 25 mile second trip to the bungling dealership. My 4.0 has the vertical mount.
Erik
88 Comanche
leaking in area of the oil filter gman OEM Tech Discussion 2 December 8th, 2003 00:02
Alum Foil heat shield?? kccherokees Modified Tech Discussion 5 August 26th, 2003 07:08
Changed ATF and filter = slipping trans LawlessXJ OEM Tech Discussion 15 August 25th, 2003 16:04
Compresion retest...survey says Rings? Ghost OEM Tech Discussion 5 April 1st, 2003 17:12
