Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Adventure Forum
Adventure Forum A place for outdoor side of your XJ/MJ. Discussions revolve around camping, equipment, and camping trailers. As well as outdoor activities that take off from your XJ/MJ like hiking, geocoaching, and rock climbing. Also the place to discuss tips and hints for the best places to camp off the beaten path.
  #31
Old April 11th, 2019, 22:08
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
Re: My M416 restomod/hole to throw money in
my dads willys has similar shackles...
looking good
mac 'cant wait to see it this summer' gyvr
Retired MWC BOD / Consultant
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old April 12th, 2019, 17:14
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
Got it back on the tub tonight after I picked up some of my mess.
Mocking up the mount brackets. Original m100 trailer tubs were welded to the frame. I’m going to weld mount tabs to the tub and use rivnuts in the frame rail to mount the tub.
Very similar to the way the later m416 tub is mounted. 6 on each side and 3 on the front and the back.
Old April 14th, 2019, 08:10
RedHeep's Avatar
NAXJA #1499
Old April 14th, 2019, 15:40
RedHeep's Avatar
NAXJA #1499
I finished up 1 side and the back of the frame with rivnuts before I realized I didn’t have any more 3/8” ones.
So I started putting 1/4x20 rivnuts in where I wanted to clamp the 7 wire cable from front to back.
I decided to run the wire on the bottom of the frame rail so I didn’t have to drill more holes in the crossmember.
The cable will run to a 7 wire junction box and then split to two 4 wire cables for the tail lights on each side. The other 3 wires are for whatever I want in the back that needs power, like lights or something.
I’ve owned enough trailers to know that wiring doesn’t last the life of your trailer so I’m planning ahead to replace it when the time comes.
Old April 14th, 2019, 22:23
Anak's Avatar
Anak Anak is offline
Stranger
Those junction boxes are a wonderful thing.
I have gone to setting up my trailers with one of those right in the front. That way when the dog gets to hankering for trailer wiring plug again I have an easier job of swapping out that first few feet.
Old April 15th, 2019, 07:26
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Saweet project man!
97’ XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old April 17th, 2019, 16:55
RedHeep's Avatar
NAXJA #1499
I have one for the front that’s going to run the 7 wire connector to the truck. I don’t need 7 wires but it will be nice to have charging power for the trailer batteries when we’re on the move.
Old May 5th, 2019, 18:08
RedHeep's Avatar
NAXJA #1499
Some progress today.
Ran clamps for the tail light harnesses.
Finished the rivnut install on the other side.
Welded the tabs to the tub on both sides.
Now the tub is mounted on both sides. I had to order more tabs for the front and the rear.
Old May 6th, 2019, 07:11
macgyvr's Avatar
NAXJA Member #120
Did you weld in your slippers?
mac 'get your Rick Pewe' on' gyvr
Old May 6th, 2019, 20:09
RedHeep's Avatar
NAXJA #1499
I welded in slippers and shorts because I wore shorts to Dover and fried my shins and ankles so bad it still hurts.
I did put a long sleeve shirt on because I was getting sparks on my arms.
Old May 7th, 2019, 19:40
Anak's Avatar
Stranger
I made the mistake of welding in the wrong footwear once. I don't intend to ever do it again.
It was one of those things where a buddy dropped off his truck and I took it over to another buddy's shop to use his lift to weld in a new muffler. It wasn't until I got the truck up on the lift and started working on it before I realized my mistake. It just didn't seem worth it to get the truck back off the lift and drive back home to get real shoes. Well, I managed to drop a dingleberry right between my toes. I swear those nerves were still complaining that my foot was on fire 12 months afterwards. I have become pretty insistent about always wearing real shoes.
Old May 12th, 2019, 12:39
RedHeep's Avatar
NAXJA #1499
Working on the last couple mount tabs and closing up the corners today. My welds are mine and thankfully not on anyone else’s gear.
Old May 31st, 2019, 19:35
RedHeep's Avatar
NAXJA #1499
Finishing up all the welding today. Had to put pockets in to clear the drain plugs in the tub.
Put a crossmember in to support the batteries inside the tongue box.
Put 3/4” led markers up front in case the super troopers of the DE state police want to hassle me.
Took all the brackets off, pulled all the harnesses off and hit the frame with a wire wheel. Tomorrow it gets por-15 and then everything goes together for real.
Old May 31st, 2019, 19:39
RedHeep's Avatar
NAXJA #1499
I bought a HF tongue box and it fits pretty good.
I got new lenses for the tail lights. They already have led bulbs in them and the convoy lights will be on a switch for fun.
I ordered a new parking brake handle but the surplus place sent me the wrong one. It’s going to get relocated on the inside passenger tongue rail with an additional bellcrank and custom rods and clevises.
Old June 1st, 2019, 14:31
RedHeep's Avatar
NAXJA #1499
Shock mounts cut from the original brackets and welded on. I didn’t have good measurements so I looked at pictures and took a swag at it.
Cleaned, wire wheeled and degreased. Installed the last two rivnuts for the tongue box and then started painting.
Rate This Thread:
WTT Restomod 1968 Chevrolet C10 for XJ or TJ spazzyfry123 SEC For Sale / Wanted Forum 19 July 25th, 2011 13:47
M416 Trailer IH8RDS Non-Tech / Off Topic 79 November 11th, 2008 13:59
M416 wndrlst For Sale: Private Party Only. XJ ITEMS ONLY 0 December 31st, 2006 13:03
7.75" Drop shackles, Hole to Hole boise49ers Modified Tech Discussion 9 December 16th, 2004 11:00
