iluv83vettes
- Houston
I have a 44 out of another cherokee that I did the crown vic disc swap. when I did the swap and put the longer studs in the axle shaft one of my lug nuts got messed up and wouldn't go on. No problem i thought i'll just run with 4 lugs until I get to O'rielly's and get another nut and then put it on there. So I'm driving there and I hear this pop noise and feel it jerk. well the one stud without a nut went back into the e-brake area and destroyed all that and the axle seal, so i get a new seal and bearings and all that and get them pressed on and fix the brakes. Every thing went in together great tonight and then I bled the brakes and went for a little test. After I drove down the driveway and back my friend asks me if my wheels normally wobble. I say no and tell him to drive down the driveway and back. I see the wheels wobbling in sync where the tops of both wheels go right then left and back like this
back and forth back and forth
so my thougts are that the diff is messed up because I don't know why the left wheel is wobbling when the right wheel was the one that popped.
Please help...
Please help...
