Old July 2nd, 2007, 09:12
Vince's Avatar
Vince Vince is offline
Swapping early NP242 for a late NP242
My front shaft bearing on my 1993 NP242 needs replacing and I opted to swap out the transfercase with another from a junkyard. The replacement 242 was purchased over the phone with a short warranty and arrived today. The 'new' 242 looks in good condition but has one major difference to the one already in my Jeep, the tailcone is the later design with the seal on the shaft instead of on the yoke.
Can I use my existing rear driveshaft and slip yoke with this transfercase? I am assuming all I need to get is the rubber bellows that goes over the shaft and yoke? Or do I need a slip yoke to match this transfercase as well?
wnated early 90's late 80's xj rwallace Wanted: Private Party Only 1 January 7th, 2007 15:34
Seat interchangability for early/late models AJPulley OEM Tech Discussion 1 May 22nd, 2006 18:48
atlas II/ early aw4/ NP242 swap jeepnuts311 Modified Tech Discussion 21 February 15th, 2006 14:10
Is it worth swapping the np231 for the np242 summitlt OEM Tech Discussion 35 December 18th, 2005 08:41
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 12:48
