NP242 Need HElP
308turbo
NJ
i have a 92 XJ got it with a blow up NP242....Got a NP242 from the junkyard..Afetr i took the old one out i realized that the rear cone cast cover that the speedo goes into is different....
The one that came out covers where the rear drive shaft goes into....
The New one has the shaft with the spines on it out in the open and there nowhere to even bolt the tiny cone peice on....
My question is Do i need the cover???? i pretty sure i do
Other question can i swap the one from the other If so whats all involed in doing so
thanks for all the help
Robbie
It sounds like the 242 you got from the Junkyard is a late model, they didn't have a tailshaft cone, just a seal on the speedo housing. YOu shouldn't need the cone part. Just bolt it up and run the d/s.I believe that the input splines should mathc, I forgot when they changed from 21 to 23.
the spines match because i checked that i just wasnt sure if i really needed that or not.....sick then i can put this B*tch back together tommorrow .....wat do you mean by run the D/S????
thanks alot
robbie
d/s = driveshaft
