Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > JeepSpeed, Prerunner and Competition Tech Forum
JeepSpeed, Prerunner and Competition Tech Forum For Discussion of Modications related to Prerunning, JeepSpeed, KOH, Rock Racing, and any other speed based competitions
Old March 13th, 2021, 19:18
luv4wheel luv4wheel is offline
1989 XJ 4600 koh emc build
Well I got her home today. Knocked on a door and got a free 4.0 auto XJ with a title. Plan on doing Atlas, super 60 front, 14 bolt rear so this was a perfect specimen! Ready to start building.
Iíve built some Toyotaís but this is my first jeep wish me luck!
Old March 22nd, 2021, 17:03
Calvin Bnvds Calvin Bnvds is offline
Re: 1989 XJ 4600 koh emc build
Woah, it seems like you have an interesting project that will keep you busy for the next couple of months. Make sure you keep us posted with the progress of this build.
Old April 1st, 2021, 12:40
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
If I can offer you some 4600 advice..
KEEP IT LIGHT.
If you're gong to do a super60 and 14 bolt, don't truss them, you don't need to, and dont get fancy with super heavy brackets. Keep it simple and light.
Having that much extra unsprung weight over a 44/9 type setup is already going to cook your shocks on the choppy stuff.
Old April 1st, 2021, 14:35
Thanks for the tip.
I figure I am going to be 230lbs heavier with each front and rear axle. I know you can do a lot of stuff to save weight on those big axles so I was going to implement that as much as possible to keep it light.
I reached out to Deavers to see if the extra lbs will affect spring performance but I haven't heard anything back.
As far as the build... I picked up some rollers for cheap ($200). Picked up a new hood a set of spare doors to build (110$). I ordered the Atlas, Stiffeners from DB Metalworx, and Deavers front and rear. Parts ordered are delayed until May-June except the stiffners I got those!
Still scouring the junk yards for my axles...
Old April 2nd, 2021, 11:44
cal's Avatar
cal cal is offline
If you havent bought axles yet, go sterling rear and keep the metric bolt pattern.
The sterling stuff is hubcentric which is easier on your wheel studs, you will be using off the shelf unit bearings instead of paying for branik 8x6.5 ones, and at the end of the day the sterling is stronger than a 14 bolt.
Old April 2nd, 2021, 16:22
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Aluminum 14b hubs are cheaper for the 14b and it's only 40lbs heavier than a semi float 60 (Which you ran in 4643), also I don't know how an axle that lacks the 3rd pinion bearing is somehow stronger/superior.
Also for $248 each, you get 8x6.5 brand new unit bearings on ebay or $75 each to have your existing ones redrilled, then the world of more common 8x6.5 beadlocks become available to you.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old April 2nd, 2021, 11:45
cal's Avatar
cal cal is offline
On leafs, consider doing the Bronco Q80 conversion instead of running the XJ G9 leafs. They are longer, and you can get a full 12" wheel travel out of them without inverting them which will make it WORLDS easier to tune your car. With G9's, you invert ~2" at full bump and the rear will want to kick up hard after every hard hit.
Have you read our build thread through? I think we covered that pretty thoroughly there.
Did Deaver set you up on the racer program yet? If not I can drop by and make an introduction for you. We got to know those guys really well.
Old April 6th, 2021, 15:59
I havenít read through your build. Iíll get on that!
I havenít heard back from deaver. I ordered my springs through polyperformance. Iíd appreciate the introduction very much!
The all terrains are just to roll axles around, set driveline angles, etc. race tires are still on my list lol.
Thank you for all the advice and help.
Old April 7th, 2021, 18:12
Scored running/driving drivetrain from 1989 XJ 200$
And picked up 23 spline AW4 that came with a free Bambi pusher(for resale) 100$
ĎOh ya itís all coming togetherí
Old April 2nd, 2021, 11:46
cal's Avatar
cal cal is offline
I hope you aren't planning on racing on those all terrains?
Look at the Falken MT or one of the Nitto MT's. We found the Falkens to be most durable.
Old April 2nd, 2021, 16:28
cal's Avatar
cal cal is offline
I don't think the 8x6.5 stuff is as excessively common as it used to be.
not calling it rare, just not a money saving exercise.
And really how is another pinion bearing any better?
Old April 2nd, 2021, 16:49
Coffee Drinker
The 3rd pinion bearing is the reason ford 9's are the gold standard when it comes to 3rd members in drag racing.
Well, I have 8x6.5 wheels on my rig, 8x6.5 wheels on my tow rig, 8x6.5 wheels on Avery's rig... I'm surrounded by 8x6.5 based rigs. Worst comes to worst, humvee beadlocks are 8x6.5, border patrol hutchinson beadlocks are 8x6.5.
As you said, this isn't a cost saving adventure, but if I'm in a bind, I like parts commonality.
Old April 12th, 2021, 05:50
89Mock 89Mock is offline
In to see progress.
The whole Ďextra bearingí advantage of the 14 bolt is for people who love 14 bolts. Two weak bearings vs one stronger bearing is the argument.
Metric wheels are probably a better choice because theyíre so common now. This isnít 1997 where everyone is 8x6.5.
Old May 15th, 2021, 22:43
I finally got my 08í super 60 in. Took a guys advice on here and grabbed one on eBay 534$ to my door. Came in with stage 2 weight reduction (rust). I canít complain at that price. Iíll take some time and clean her up while Iím cutting all these damn brackets off lol. Ordered busted knuckle willwood disc brakes to save some weight.
This weekend I finally found my 14 bolt under a 94 Gmc 3500 158$ from the yard. Had to snap 2 ubolts with a breaker bar and sawzall 1 shock and 1 ubolt (someone tried to remove it and rounded a bunch of bolts). Brought her home in the Taco just to see it squat lol. Ordered all the stuff from lugnut4x4 to make it disc with brake and save some weight!
Old May 15th, 2021, 23:07
I failed to Post Photos on the last post. They didn't come through. enjoy the photo dump boys.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Rate This Thread:
4600 Class KOH XJ CherryXJ JeepSpeed, Prerunner and Competition Tech Forum 27 September 7th, 2020 04:31
KOH 2018, 4600 10 Day Build GMR_CO JeepSpeed, Prerunner and Competition Tech Forum 24 September 21st, 2017 16:09
1989 Jeep Cherokee Laredo Build OneNineEightNine Modified Tech Discussion 12 March 24th, 2013 09:48
Non Jeep--- Rustler w/MM 4600 tharlanjr SoCal For Sale 4 January 30th, 2010 01:06
1989 jeep comanche build thread f1tbiker6 Modified Tech Discussion 52 November 17th, 2008 21:00
