wildman
- Jennings, LA
I removed the canister end with no problem, however, when I got to the other end, I pulled the cotter pin, and removed the castle nut, and can't get the bolt out. Is it just rusted that bad? I've been soaking it for 3 days so that it would be easy to remove, and it isn't. I tried putting a hardwood block against the bolt and pounding on it with a ballpean hammer. Then I took a large punch, just big enought to not damage the threads but still put a pretty good lick on it, and knocked the **** out of it with a maul. It never budged, not even a little bit. i noticed that there is a nut between the bushing and the link, but I can't turn it, not even with a cheater pipe(I tried this before I went to pounding on it). any suggestions? hit harder? turn harder?
