wireman121
- NJ
Have a 1998 XJ with AW4. All forward gears work without any issue. When i shift into reverse after sitting for about 1+ hours, there is a VERY slight creep backwards. If i rev the engine, it acts like its in neutral. After revving for about 10 seconds, it will drop into reverse. After that, reverse will work fine as long as I continue to drive it. But if I park it for 1+ hours, the problem comes back.
Reverse is strong once its engaged, so I'm ruling out any worn clutches or bands and leaning towards a sticking solenoid or something in the valve body?
