Old May 5th, 2005, 14:53
Bender Bender is offline
FYI Another stroker passed the e-test.
4.6L home built low buck stroker based off 1988 RENIX system.
24# injectors, no intake mods, 10k miles on engine so far and running 91 octane gas.
RPM 1703
HC ppm Limit 90 Reading 15
CO% Limit .5 Reading .03
NO ppm LImit 979 Reading 26
At Idle 950 rpm
HC ppm Limit 200 Reading 31
C0% Limit 1.0 Reading .05
So, it not only passed, it passed by a long shot.
Old May 5th, 2005, 15:06
XJZ XJZ is offline
Re: FYI Another stroker passed the e-test.
Glad to hear it.
Has any one out there had problems with a stroker passing emmissions?
Enquiring minds want to know.
Most seem to do quite well.
Old May 5th, 2005, 15:18
old_man's Avatar
old_man old_man is offline
Mine was running a bit too rich at this altitude (5300ft) with the 24# injectors so I did a MAP sensor mod and it passed with flying colors.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old May 5th, 2005, 17:39
frsno jeeper frsno jeeper is offline
I have not Confirmed, or I used a BAD email Addy
anyone else with a renix head stroker?
Test #1 Glenn B TEST Forum 5 December 7th, 2003 13:27
Test ; similar threads F. F. TEST Forum 2 December 6th, 2003 20:12
Ok Test it XJJPR TEST Forum 5 December 5th, 2003 18:45
test WebTeam TEST Forum 0 December 5th, 2003 10:38
