Old October 2nd, 2017, 13:42
paroxysym's Avatar
paroxysym paroxysym is offline
whats it take to run 32s?
I noticed a jeep for sale locally that was running a set of JK wheels with the stock bridgestones on them. the stock bridgestones on a JK are a 32x10(roughly). im wondering what it takes to run that size tire on these? I know on my old 95, it took 3" and 31s fit comfortably. this XJ with the JK wheels has alittle room in the fenders, but not much.
those running 32s, what are you running for a lift? would you go smaller lift with a set of flares to open the wheel wells up?
Old October 2nd, 2017, 13:43
in4aride in4aride is online now
Re: whats it take to run 32s?
Use the search. Tons of threads on this.
Old October 2nd, 2017, 15:29
Jeep Driver Jeep Driver is offline
31s with NO lift.
32s and you will cut.
Old October 2nd, 2017, 23:23
Francesco Francesco is offline
A 32 should fit no problem with a little lift and bumpstopping. You could fit 31s stock I'd assume, so what's another inch
Old October 3rd, 2017, 16:12
techno1154's Avatar
techno1154 techno1154 is online now
[/QUOTE]
Off topic,...
Who made that front bumper? How far does it stick out past the grill, approximately?
That is a beautiful MJ.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 3rd, 2017, 18:35
Warrior Products, about 4" out.
Old October 3rd, 2017, 18:59
techno1154's Avatar
Thank you. I will look into it.
Patrick
#594
Old October 3rd, 2017, 21:19
ehall's Avatar
ehall ehall is offline
If you don't plan to go off-road you could probably get away with 3" of lift and a little trim. If you plan to go off-road much, you will need 3-4" of lift and a lot of trimming to allow for articulation.
my '91 beater rebuild
Old October 4th, 2017, 07:24
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
This.
I used rub with 31's and a 3" lift before some minor trimming
Old October 4th, 2017, 09:25
jabinco jabinco is offline
When I started building my XJ, I chose 4 1/2" and 32s thinking I could get away with not trimming. I was wrong, it rubbed before I backed out of the driveway. Sooo... trimmed fenders (for bushwacker flat flares), now I have plenty of room.
Old October 4th, 2017, 10:45
denverd1's Avatar
denverd1 denverd1 is offline
bumpstop or trim
Old October 4th, 2017, 17:01
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
I ended up with 5.5" lift on my '98.
32 x 11.50 BFG/MT's on 7" rims, 4.5 BS steelies...
Stock flairs, no trimming. No trimming front fender inner wheel well seam.
Different front bumper, so no rubbing there.
Stuff's easily at all corners, with no rubbing anywhere....
I know if I go 33's; then it will be trim city, and wider 8" rims. Current set up doesn't warrant moving up, for 1/2 inch more of clearance. This set up gets me to where I need to get...
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old October 4th, 2017, 18:05
Afireinside Afireinside is offline
Jk wheels will need a spacer. There offset kind of changes thing's! I run a 3" lift with 255/70- 17's with no rubbing or cutting. I initially ran duratracs 255/75 r17 and they fit fine in normal driving situations but would rub if stuffed certain ways.
How do you post pics here?
Old October 10th, 2017, 11:16
mcguyver_xj's Avatar
mcguyver_xj mcguyver_xj is offline
your mileage may vary but there are people who have run 35's on no lift and I have seen 6.5" lift rigs only running 33's
Whats next? jamesbtaylorjt Modified Tech Discussion 6 October 30th, 2011 18:31
anyone know whats up with RE chedisme North Atlantic Chapter 23 February 10th, 2011 13:49
Moab Prep: Whats done/Whats left IslanderOffRoad 25th Anniversary Celebration! Moab, Utah 138 October 6th, 2008 23:02
whats next? foxwar71 Non-Tech / Off Topic 1 March 7th, 2007 23:06
Whats different? WaXJ_Skier NorthWest Chapter 10 March 1st, 2007 18:17
