99XJSE
- Columbus, IN
I have a specific question in regards to caster angle in regards to a small lift.
I bought a rust free 99 XJ about a year back that I have been slowly fixing up with the soul purpose of being a daily. I installed Rusty's 1.75" budget boost kit which was just spacers up front and shackles in the rear.
Since the lift I have been experiencing death wobble at highway speeds 70mph when hitting a bump on the highway. I can start feeling a small shimmy and instability when I hit 55-60mph.
Here is some background info first so you know what I tried:
Verified trackbar and everything I unbolted is torqued correctly. I had my wife turn the steering wheel back and forth while I watched the trackbar and tie rods for movement and didn't see anything.
Took the Jeep in for an alignment and they could only correct the toe.
Toe
0.13 left
0.14 right
Caster is locked at
+6.2 degrees left
+6.5 degrees right
The Rusty's directions recommend the caster to be set at +7.5 degrees. We were going to set the caster at the recommended +7.5 degrees but the passenger side control arm bolt was locked up to the bushing sleeve and we couldn't get this to pushout.
Factory caster specs are +5.25 degrees to +8.5 degrees and +7 degrees preferred.
My question is would adjusting the caster +1 degree going to make a difference especially since I'm within factory spec?
Basically Im trying to decide if I should spend time to try and get that control arm bolt free or if that would be a waste of time and moved on to the track bar and tie rod ends.
Side note: after the alignment it didn't correct the death wobble so I put my TJ wheels/tires on the XJ which also had no affect so I can rule out tires. The wheel bearings were replaced 3 months before the lift too. So if Caster isn't the issue, next steps will be new track bar and tie rods, followed by ball joints last.
Thanks!
Toe
0.13 left
0.14 right
Caster is locked at
+6.2 degrees left
+6.5 degrees right
Thanks!
