Copy and paste from another XJ forum
Last night my CEL came on and went to scan the code. P0132 came up. Bank one sensor 1 upstream O2 sensor. I replaced that o2 sensor back in May
This morning, I noticed a rough idle along with the present code. I cleared the code to see if it would come back. It did not for a bit of driving but I still had a rough idle. I pulled the Throttle body out and the upstream o2 sensor. The TB was not dirty and the IAC was somewhat coated. I cleaned both
The O2 sensor was covered in carbon. I cleaned that as well. During the whole process I saw that the pcv tube connecting to the intake was not completely in. It's a newish hose with a hose clamp. I retighen that
Now after some driving, I dealt with some bucking, sorta the same thing that happened before replacing my 02 sensor back in May. The CEL came back on and it's P0171- system too lean.
I ordered a new o2 sensor but it won't be here till Tuesday. At this point im sorta afraid that an o2 sensor isn't my problem.
What should I all look for besides leaking vac lines?
