P1391 code
Badjeep2001
MT
2001 xj engine rebuilt comp cam. I had the code show up after new motor now I have tried just about everything new cam and crank sensors new coil pack new fuel pump. Used a drm 3 scan tool it said they are in sync but randomly the jeep will not start
Sent from my SM-G965U using Tapatalk
Did you use Mopar sensors? On my 2000 it was the cam sensor that caused what you describe.
I had replaced the whole synchronizer then I put the factory one back after the code to try
When it decides not to start every once in awhile it will pop through the intake but if a leave the key on until all the lights are out about 95 % of the time it will fire right up
