Old December 5th, 2006, 06:38
RichP's Avatar
RichP RichP is offline
Re: Overheating Issues...
OK, it worked fine before the pump and did not work after the pump. Remove the belt, spin and turn everything that turns in the belt path then with the key and no belt see how it turns over. I've seen old removed pumps seize after sitting on the shelf for a few months.
Old December 5th, 2006, 07:22
Bouncy's Avatar
Bouncy Bouncy is offline
Stuck t-stat?
If I remember correctly, you like the closed systems. Maybe air in the system.
Blown head gasket?
Just a couple of ideas.
Old December 5th, 2006, 08:40
stewie's Avatar
stewie stewie is offline
good point. i was thinking of returning it to its last known working order. ie put the old pump back in and see. just to start to systematicaly eliminate possibilities.
Old December 5th, 2006, 08:54
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
Originally Posted by DeftwillP
Hell must be freezing over because Jon shouldn't need ask for 4.0 help.
Wish I could help Jon, best of luck
I know thats right.....I wish I could give you a hand but I dont know much about the older 4.0's....
And BTW, I know its getting off topic, but can I like this quote....mind if i use it?
Originally Posted by 5-90
When you get too close to a problem, it tends to give you blind spots...
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
Old December 5th, 2006, 14:40
5-90's Avatar
5-90 5-90 is offline
99SPORT - go ahead. I've been quoted before, and I find it flattering...
RichP - I checked the pump (and everything else!) while I had the belt off, and everything spun freely. I also re-checked the pump once it was in place, while I was putting the pully on.
flht1997 - all screws went into the exact holes they came out of, where possible. There's only one long screw to mount the water pump - and it's fairly obvious where that goes.
stewie - I'd put the old pump back in, but it doesn't hold water. And I'm running low on R/O water.
I'll probably take the belt off and see what that does, maybe I missed something? However, I'm taking to-day off from that little nuisance, and getting to restoring my office to its former usefulness. We re-arranged house last week-end, and I'm still putting things back to rights!
5-90
Old December 5th, 2006, 15:24
dizzymac's Avatar
dizzymac dizzymac is offline
Know that feeling Jon about being to close, when we were looking for shorts in the 91' I know I killed off what few remaining brain cells I had left.
The only thing I could could think of was there more heat than thought and maybe it did start to seize, sure hope not.
It would be nice if it were something simple like like a poor ground, but I just can't see that happening on one of your vehicles.
Wish I could be of help.
Old December 5th, 2006, 16:53
flht1997's Avatar
flht1997 flht1997 is offline
darn! i thought i was on to something with the bolt thing. i am out of ideas. More voltage drops, and amp readings the powers got to be getting used somewhere.
Old December 8th, 2006, 22:45
Hypoid's Avatar
Hypoid Hypoid is offline
No, I have not forgotten. If it can stump Jon, I need to pay attention. lol
My thought as well. My second thought was of a really good motorcycle mechanic that resurrected my bike years ago. One thing he did was install a new ground strap. After two weeks of 90*, + 90% humidity the starter wouldn't work. Everything else was fine: Lights, charging system, battery. I could push start it and go anywhere I wanted. I took it back to him, he busted his noodle for a few days with no result. Out of sheer desperation he pulled the ground strap, which looked fine, and sanded the frame and termination; problem solved.
I dunno, if your cooling system leaks, your engine is overheating, and your hood is shut, I would think that it's hot and damp in there. JMHO
Old December 9th, 2006, 11:08
badron badron is offline
The best word I could give is START OVER. Check your Ohm/volt meter. Clean everything again. Do a load tests on the battery. Then right down the line again. Suspect that "known good starter". Suspect everything. Twist and tape everything as you go.
Old December 9th, 2006, 11:20
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Why not pull the sprak plugs and crank it after checking the cylinders with a flash light first? Also might try cranking it with out the belt on just once.
Old December 19th, 2006, 16:37
flht1997's Avatar
did this problem get solved?
Old December 19th, 2006, 17:10
5-90's Avatar
To be honest, I haven't been able to work on it. Seems like everything else around here has decided "go boom!" all at once. I've had my kitchen torn apart twice since this has gotten silly...
"It never rains, but it pours." Once I get caught up and can start working on this again, I'll take notes. Once I finally figure it out, I'll let you all know. Meanwhile, I'll finish fighting off this URI I've managed to pick up (it never rains!) and I'll get going on this again...
5-90
Overheating too... socratica OEM Tech Discussion 8 August 22nd, 2006 11:10
radiator leak, overheating issues HeightsHoustonXJ OEM Tech Discussion 5 July 12th, 2006 08:35
Heating and overheating issues Mikel OEM Tech Discussion 2 February 23rd, 2006 21:26
Tire size issues Issues johnwaggle Modified Tech Discussion 4 December 23rd, 2005 22:55
overheating issues rngrfrd2000 OEM Tech Discussion 6 February 27th, 2004 11:31
