Old December 22nd, 2005, 17:49
johnwaggle johnwaggle is offline
Tire size issues Issues
I have a 92 cherokee and I'm planning ot put a 4.5 rubicon lift on it and i want to go with a tire around 33 inches. With the rear end will there be any issues as far as gear ratio that will have to be taken into account.
Old December 22nd, 2005, 17:58
87manche's Avatar
87manche 87manche is offline
Re: Tire size issues Issues
auto or 5spd? I've got a 5 spd and with 31's and 3.07's there's a noticeable difference from stock. Not a whole lot of getup and 5th is basically worthless unless I'm doing 70.
I've also assumed you've got the 4 liter.
Old December 22nd, 2005, 18:01
XJ Wagon's Avatar
XJ Wagon XJ Wagon is offline
NAXJA Member #1360
You need to find out what gear ratio you are running now. You are going to loose power. There is a gear ratio chart on 4wheelparts.com in the tires. This will give you an idea of what ratio you will want to be at.
Give you VIN # to a dealer and they can tell you what ratio you have, at least what it was stock.
Old December 22nd, 2005, 18:52
bj-666's Avatar
bj-666 bj-666 is offline
YES
Old December 23rd, 2005, 22:55
Only In A Jeep XJ's Avatar
Only In A Jeep XJ Only In A Jeep XJ is offline
Originally Posted by bj-666
YES
X2 You ar going from about a 27 in tire stock to a 33 in thats alot up to 31 with minimal power loss on an auto but really big loss on a 33 i ran stalk gears and 31's for a while and you can tell a big difference especially on the highway i had no power at 70.
Spare tire carrier dana44 OEM Tech Discussion 8 September 30th, 2005 15:35
Biggest original tire size?!? HEKULIINI OEM Tech Discussion 8 February 8th, 2005 16:41
Tire size questions the_bandit87 Modified Tech Discussion 2 June 28th, 2004 20:53
thoughts on tire size? Codhead Modified Tech Discussion 5 April 30th, 2004 14:12
Help - Need Tire size ideas! JHKolb North Atlantic Chapter 19 October 16th, 2002 16:56
