Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > SierraFest 2012
SierraFest 2012 August 9-12, 2012 at Deer Valley, CA
  #16
Old May 25th, 2012, 12:32
SharkXJ's Avatar
SharkXJ SharkXJ is offline
NAXJA Member #1177
Re: What is your " To Do List" before SF2012?
Well - let's see.
Finally cut and fold qtr panels so I can install my tire carrier.
Buy New rear leafs - gonna need something stronger to hold up the tire and tire carrier.
Maybe throw on the Frame Stiffeners
Add Rock Lights
Install the upper rear Qtr Panel Armor I have had sitting in the garage for 2 years.
Replace both Pinion Seals
Radiator Flush
Man - i got a lot to do - LOL
Look Up!!!!!!
  #17
Old May 28th, 2012, 10:07
Boatwrench's Avatar
Boatwrench Boatwrench is offline
Parts Collector
Get the thing running...
Nobody's right if everybody's wrong
  #18
Old May 30th, 2012, 08:40
Rob D's Avatar
Rob D Rob D is offline
All I have to do is install my front 44. Finish off the drag ling and track bar, which means cutting to the right length and welding them up. Then measure for my front drive line and have it cut down to fit. For some reason it seems to help to have a front driveshaft if you want the front end to help out when in 4-Hi or 4-Lo. Go figure! Then install my skid plate under the t-case and possibly get new shoes for the XJ. (2 of the four are down to the wear ridges and the other 2 aren't much better. But i might be able to get a decent spare out of the set. My current spare is starting to dry rot)
Rob D
'91 Cherokee Larado, Full-Traction 6" coils w/ACOS's, 6.5" Clayton springs, 35" MTR's, 4:88's, 35-spline D44 w/ARB and Explorer disc's in back and a narrowed hp44 front w/E-Locker.
  #19
Old May 30th, 2012, 19:02
connor0770's Avatar
connor0770 connor0770 is offline
-get time off
-buy lots of cardboard to make it look like a cherokee so i will fit in
  #20
Old May 31st, 2012, 00:00
Jeep450r Jeep450r is offline
-Fix death wobble
-SS brake lines
-Balance front driveshaft
-Rock Lights
-Fix janky stereo wiring
-Roll cage
I think thats all.... but im sure more will pop up. Can't wait for the event!
  #21
Old June 9th, 2012, 01:29
CAJJ93XJ CAJJ93XJ is offline
install...
everything surrounding my engine
entire dash
lift
tires
detroit locker in my 8.8
regear D30 and lockright
pretty much build an entire rig
but I wanna go
  #22
Old June 9th, 2012, 01:48
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is online now
Finish cage.
Capture coils.
Longer.front shocks
Ruffstuff truss Ford 9" .
Not needed but it would be cool to link the rear sometime soon.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
  #23
Old July 4th, 2012, 13:29
cencal96xj cencal96xj is offline
-buy rock sliders
-install said rock sliders
-save up for gas!
Sent from my DROIDX using Tapatalk
  #24
Old July 4th, 2012, 15:06
JOSEJALAPENO JOSEJALAPENO is offline
Tube doors are done, New track bar is done. Just save money for gas & deside how i a going to pack up my Heep.
  #25
Old July 4th, 2012, 16:10
New list:
Build a roll cage
  #26
Old July 4th, 2012, 16:31
Originally Posted by Jeep450r View Post
New list:
Build a roll cage
before sierra fest?
  #27
Old July 4th, 2012, 17:05
Rob D's Avatar
44's done except I still need to get the driveline cut down, get the toe-in set and fix the chamber problem on the left side (parts should be here soon for that). Then wheel it
Rob D
  #28
Old July 4th, 2012, 17:59
NorCalChris's Avatar
NorCalChris NorCalChris is offline
Finish 8.8 and d30. Install axles, align Jeep, disregard females, acquire currency.
  #29
Old July 5th, 2012, 18:47
ohh yeah and i wanna try to make mounts, paint and install my roof rack, try to find a full size spare for cheap, and get longer bump stops for the front (one broke off)
  #30
Old July 5th, 2012, 22:30
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Txt you, depending on tire size I may have a spare you can use.
Side note, might want to turn off your tapatalk sig, its against the TOS.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Rate This Thread:
List all of your "heat soak", "hot soak" fixes xjtrailrider OEM Tech Discussion 89 January 21st, 2014 11:26
The "Hope I get done before Winterfest" List..... XJ&CHZ4ME WinterFest 2011 405 March 4th, 2011 16:49
Want 4"-4.5" lift, check parts list..need feedback 01sesedan Modified Tech Discussion 0 March 23rd, 2009 16:34
1988 LIST "O" NEEDED PARTS JKooshTJ Wanted: Private Party Only 2 October 11th, 2004 20:04
4.5" vs 6" lift..my list..need advice Double Down Modified Tech Discussion 10 March 25th, 2004 20:30
