Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > SierraFest 2012
SierraFest 2012 August 9-12, 2012 at Deer Valley, CA
Old February 25th, 2012, 08:32
NorCalChris NorCalChris is offline
What is your " To Do List" before SF2012?
What modifications, if any, do you plan on doing to your rig before SF2012?
My list is simple:
Build a Jeep.
  #2
Old February 25th, 2012, 09:01
SeansXJ SeansXJ is offline
Re: What is your " To Do List" before SF2012?
dodge van main leafs...steering and long arms...maybe get my sye and shaft finally...
  #3
Old February 26th, 2012, 10:00
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
too much stuff right now. Probably at the top of that list - buy a new tow rig...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
  #4
Old February 26th, 2012, 10:21
Skipper51's Avatar
Skipper51 Skipper51 is offline
I still need to put the JCR transfer case skid I have, put in HD shackle relocation brackets on, Detours Tailbone (on order since 9/2011) and their shock relocater's and cheaters that I will order, Treadwright 31's also on back order, regear to 4:10 and if I can put a E-Locker in the front.
Is this too much to do in five months? Hell no.
  #5
Old February 26th, 2012, 19:40
Rammin97's Avatar
Rammin97 Rammin97 is offline
I would like to get my 44s under the heep, 5.5 RE shortarm kit, and transfer case with SYE installed. I have everything but the frickin time to do it! I may just install the RE stuff and SYE/shaft and learn how to drive!
  #6
Old February 26th, 2012, 20:16
rocknxj's Avatar
rocknxj rocknxj is offline
Save money for gas. Otherwise, the Jeep is ready to roll.
  #7
Old February 26th, 2012, 23:41
DaveNJeep DaveNJeep is offline
Can I simply put together a list of things on the Heep that don't need to be done? It would be a shorter list!
  #8
Old February 29th, 2012, 20:15
yeah Im thinking the same now...should be at or around $5 by this trip
  #9
Old March 5th, 2012, 15:09
jeepme's Avatar
jeepme jeepme is offline
lets see fix my stupid rear ARB and maybe get my tube fenders finished, and yes save for gas money
  #10
Old March 5th, 2012, 18:37
tj'sxj's Avatar
tj'sxj tj'sxj is offline
re 5.5inch leaf pack,
8inch front springs,
push front axle forward to true,
rear axle perchs fix pinion angle,
new stereo,
pull the front doors!
  #11
Old March 12th, 2012, 22:05
JOSEJALAPENO JOSEJALAPENO is offline
Replace my stupid flex joint on my track bar. Have my tube doors built by Mr EricsXj. Save some cash for over priced gas.
  #12
Old March 14th, 2012, 21:29
byrinxx74 byrinxx74 is offline
Going to get frame sliders, Gas tank skid, Transfer case skid, Also if i can rear locker, Also some 33's
  #13
Old April 24th, 2012, 13:53
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
- dual battery
- dirtbound fan conversion
- 8.8 axle swap(rebuild LSD 410)
- dana30 swap(rebuild joints and bushings, install locker, new brakes 410)
- diff covers
- inverted t steering over the knuckle
- cb install&scanner
- sub install
- sliders
- 3.5" lift
- mount 31s
- hnt
- apn header
- 99 intake
- cowl intake
- install super40
- cargo storage rack
- rad rail shifter
- probably a few things I forgot
Holy crap....
  #14
Old May 20th, 2012, 18:01
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
- transmission cooler/ new radiator
- Shackle relocation/ rear shocks
- action fab frt bumper
- 2x6 rocker replacement
- unibody stiffeners
- cut-n-fold rear quarters
- rear locker/diff cover
- re-route exhaust
- some sort of trans/engine skid
- hydro assist.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
  #15
Old May 23rd, 2012, 22:08
Finish assembling engine
gear and lock my d30 and F8.8
Swap in my axles
Install my Bilstein 7100's
SYE and shafts
Install my rock rails
Cut rear quarter panel
Bump stops
Install my limiting straps
Install my offroad lights
Install my Deck for some tunes
gas tank skid
ALMOST THERE!
Rate This Thread:
List all of your "heat soak", "hot soak" fixes xjtrailrider OEM Tech Discussion 89 January 21st, 2014 11:26
The "Hope I get done before Winterfest" List..... XJ&CHZ4ME WinterFest 2011 405 March 4th, 2011 16:49
Want 4"-4.5" lift, check parts list..need feedback 01sesedan Modified Tech Discussion 0 March 23rd, 2009 16:34
1988 LIST "O" NEEDED PARTS JKooshTJ Wanted: Private Party Only 2 October 11th, 2004 20:04
4.5" vs 6" lift..my list..need advice Double Down Modified Tech Discussion 10 March 25th, 2004 20:30
