Gravesdiggerxj
- Salt Lake City, Utah
I have a set of Teraflex lower control arms for sale.
They will fit and TJ ZJ or XJ you want.
Good for 4.5" of lift.
Wristed in the center for more articulation with grease zerk fittings at the center.
The Bushing is welded offset (see top pic) on the axle side to gain more clearance (i.e. more droop) from the lower control arm bracket on the axle side
Paint is flawless. No scratches. Bushings are also almost Perfect
Nearly brand new condition $100 or best offer.
I can get you an eye to eye measurement if needed
