Old July 11th, 2018, 13:48
757wardaddyXJ 757wardaddyXJ is offline
Shock question
Hey guys new to the forum. drive a stock 2000 sport 4wd.
getting a brand new set of bilstein 4600 shocks from a local guy and a new in box mopar spare tire carrier.
question is the shocks are listed as 80-86 cherokee only here is the link to them.
https://norfolk.craigslist.org/pts/d...625462356.html
i assume i could make the rears work by swapping the pin style bushing.
but the fronts would not work at all since it is a different style. is there any conversion for this or should i sell the fronts and get the correct ones.
thanks guys!
Old July 11th, 2018, 15:19
sinat01's Avatar
sinat01 sinat01 is offline
Re: Shock question
I cant open the link at work, buut is it a barpin style for the front?
Old July 11th, 2018, 18:22
RCP Phx RCP Phx is offline
Re: Shock question
thanks guys!
Those are for a "SJ".
Old July 12th, 2018, 09:25
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Shock question
FYI JKS makes adaptors or you can make your own.
http://jksmfg.com/i-9056861-cherokee...k-adapter.html
It lowers the top of the shock 1" more than the stock, stem-type shocks
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Shock Question Tim00XJ Modified Tech Discussion 8 November 18th, 2009 10:23
OME shock question gm tech Modified Tech Discussion 2 September 29th, 2009 15:25
shock conversion-shock question bcmaxx Modified Tech Discussion 8 July 8th, 2008 11:12
Another shock question (sorry) Mopar500 Modified Tech Discussion 2 January 5th, 2008 10:26
OEM Shock Question 2000XJSPORT OEM Tech Discussion 4 April 18th, 2006 21:18
