Old July 10th, 2018, 18:55
alloriginaltone alloriginaltone is offline
What I learned about steering box brace replacement
It's common knowledge among XJ fans that the aluminum bracket that mounts between the inside of the steering box and the driver side frame must have been designed by the same people who make the plastic cutouts for model car parts. It is fragile and disintegrates. So, it needs to be replaced.
The issue I ran into is the steering box bolts sheared off when removing them. I sprayed them with kroil and was gentle and patient. Didn't matter. Two of the three sheared off.
The good news is when they shear they leave quite a large stub to grab onto. The bad news is that they weren't budging with a vice grip. So, I heated the area of the steering box that captures the bolt. I happened to use an "induction" heater rather than torch. Once heated, the bolts came out easily.
I was really glad I didn't have to take out the entire steering box to ream out those bolts!
Old July 10th, 2018, 21:28
Greenspan's Avatar
Greenspan Greenspan is offline
Re: What I learned about steering box brace replacement
Recently did the same upgrade when replacing my front bumper. I didnt have any problems taking them out but getting them back in was a PITA.
I had to leave the steering box unbolted (but still in the roughly same position, resting on the frame) overnight and it leaked some fluid on the ground.
Old July 11th, 2018, 12:41
sinat01's Avatar
sinat01 sinat01 is offline
heat deff helps with getting the bolts out. I had 2 snap and one actually twisted a full turn, then backed out. weirdest looking bolt youll ever see now
Brace your XJ with the Ultimate Steering Brace from BWE... Boostwerks.com Vendor Advertisements 11 May 3rd, 2018 22:55
Steering Shaft Brace? Looking for ideas for my steering problem. andrew2516 Modified Tech Discussion 37 March 12th, 2013 09:48
Rear Main Seal Replacement - Lessons Learned Markos OEM Tech Discussion 18 June 17th, 2010 16:11
Rustys steering box brace + C-Roc frame brace trickcomanche Sierra Chapter For Sale 41 January 3rd, 2010 16:00
TB brace and Steering gear brace xjjeepthing Modified Tech Discussion 8 March 7th, 2009 02:29
