Old July 9th, 2018, 15:45
Jaguarjx2 Jaguarjx2 is offline
Comp Cams 68-232-4 vs 68-200-4
Ok, I have read dozens of posts on here about cams but none comparing these two. So my question is, which cam would you recommend (preferably from actual experience). This is for my 2000 jeep Cherokee 4.0, bored 30 over with a 0630 mildly ported, stock valves and magnum springs. port matched intake and aftermarket header. 62mm throttle body. It has a 4.5" lift with 4.10 gears and a aw4 attached.
As a side note, engine was rebuilt with a 0331 head and the 68-200-4 cam but feels under powered. I plan to tear into it and check the cam timing and am planning on porting 0630 head I have and toss it in. Which is where I am debating on swapping out the cam as this will be the time to do it.
Old July 9th, 2018, 16:05
RCP Phx RCP Phx is offline
Re: Comp Cams 68-232-4 vs 68-200-4
I tried to tell you already, but now I suggest you talk to Russ(there's a way about his speaking)!
Bishop-Buehl Racing (626)967-1000
Old July 11th, 2018, 12:54
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
The Comp Cams 68-232-4 cam is the one Russ recommends to use with his 4.6 stroker build. Call him.
Speak the Truth-Question with Boldness-Speak without fear.
Old July 11th, 2018, 13:19
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
I ran a 68-232-4 in a stock jeep motor and it had way more mid range power, but would fall off over 4,000 rpms due to valve float. If your magnum springs are up to the task, than that's the cam I'd run.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old July 11th, 2018, 13:29
Magnum springs, w/o specs that mean nothing. I used to have a grab box at work with a 3/4 race cam in it, I don't know how many times people tried to buy it with 1/4 of the cam machined off !!!!
Old July 11th, 2018, 13:37
XJEEPER's Avatar
NAXJA Member # 13
3/4 Race Cam for the win!!!!
Old July 17th, 2018, 18:44
Jeepedo129 Jeepedo129 is offline
I am on my second 68-232-4. I didn't have any complaints with the first one, but the #4 exhaust lobe flattened out on me, but I'm pretty sure that was do to other issues.
I just reinstalled a new one, and just as some advice, the cam card that comes with that cam is most likely going to be wrong. Comp prints the card with the timing events notated as @.050 however the events on the card are actually measured as @.006. Also, that cam will most likely be -4* retarded, so you may need to get an adjustable timing set. As others have said, it had good torque and a little bit of mid range but up higher it defiantly trails off. Could be from valve float, or that is just the design of the cam.
Comp cams MasonMcK Modified Tech Discussion 5 July 25th, 2016 10:22
Comp Cams EXTREME 4X4 kit? opsjunkie93 Modified Tech Discussion 9 June 18th, 2010 09:12
COMP CAMS install; need some help JENSSEN Modified Tech Discussion 0 June 2nd, 2008 15:08
comp cams 68-201-4 jeepin270 Modified Tech Discussion 3 April 5th, 2007 03:35
Comp Cams 68-232-4 RCman Jeep Street and Performance 3 November 30th, 2005 11:59
