Old July 8th, 2018, 12:10
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
99 RE 3.5 st arms, need adjustable?
I have a 3.5 re lift and the front drive shaft has highway vibes. How much can adjustable arms help this?
I don't want a fix that makes steering dangerous.
Old July 8th, 2018, 12:14
Overland's Avatar
Overland Overland is offline
Re: 99 RE 3.5 st arms, need adjustable?
I'd have the caster checked before I changed parts, it may not be the issue. I say this because I've had a couple of them at four inches on stock control arms and never encountered a problem.
Old July 9th, 2018, 07:40
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Adjustable control arms will allow you to tune the pinion angle, assuming the vibes are caused by the pinion angle.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old July 9th, 2018, 11:47
VAhasnoWAVES VAhasnoWAVES is offline
if the factory castor adjuster is not maxed out you could start there rather than spending money.
the stock adjusters were plenty when i had those arms myself.
Old July 10th, 2018, 00:06
ill look into the caster adjustment. If the vibes are not from the pinion angle, wouldnt these be notice much more often?
thus far its about 65mph itll start a bit. sometimes down/uphill or how the load is be put on the front will allow me to go faster before the vibe is noticed, this allows makes me think the vibes are from pinion angle.
Old July 10th, 2018, 10:33
there should be no load in 2wd.
if castor is acceptable... pull the drive shaft and try driving it in the same manner. if it disappears then you are likely looking at a bad joint in the driveshaft or too steep of a pinion angle. if that is the issue, you will have to dial back the pinion and compromise on the castor.
what year is the jeep? what motor/trans/case? high pinion or low pinion axle?
Old July 11th, 2018, 12:15
99 4.0/AW4, np 242 with tc drop, hp d30, RE 3.5 super flex lift, 33s
i have driven with the DS removed which solved the vibe issue. I also hold that its the pinion angle because as far as the life of a spicer u joint goes, its still fairly new. Does that sound like a fair bet leaning towards pinion angle?
Wtb short arms, drop brackets or adjustable arms. bwfdrums MWC For Sale/Wanted Forum 1 June 27th, 2012 11:33
Adjustable upper control arms made from stock JK arms? tonyxj2k Modified Tech Discussion 2 September 23rd, 2011 11:48
RE lower adjustable arms(Super-Ride lower Adjustable) Comanchedude For Sale: Private Party Only. XJ ITEMS ONLY 4 February 12th, 2010 12:14
still need adjustable arms f1tbiker6 NAC Classifieds 13 July 30th, 2009 18:37
Non-adjustable/adjustable lower control arms Stick Wanted: Private Party Only 5 March 21st, 2004 17:23
