Old July 11th, 2018, 11:46
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
front brakes sticking
My front brakes stick every time I let off the pedal, just for a quick second. you can feel and see the front wheels wiggle once the pads let go.
my best guess is this issue below:
http://www.jeepforum.com/forum/f9/xj...rooves-924713/
I know I have seen these indentations before. I dont weld and would like to know, other than buying new knuckles, which seems kinda dumb for this old of a vehicle, is this the only way to fix this issue?
assuming anything ide find in a JY would have grooves to.
Old July 11th, 2018, 15:22
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: front brakes sticking
10 min with a wire feed welder and a grinder to smooth out the weld will get you back to good.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old July 11th, 2018, 15:34
Do I need to preheat and will a welder that works off 110 work?
Old July 11th, 2018, 19:20
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
I didn't. I just used enough heat and wire speed (flux core) to make sure I wasn't making things worse then ground it smooth
Old July 11th, 2018, 20:45
trippled trippled is offline
You'll be fine. I've fixed quite a few of these before. Really all you need is a few small tacks or a quick bead then grind it. Depending how pad the grooves are they can change your braking pretty noticeably.
Old July 12th, 2018, 16:19
ill give it a go then, doesnt seem to difficult.
Thanks for everyones help!
Old July 13th, 2018, 06:00
CJR CJR is offline
This is an interesting fix. But how do you know that the caliper piston is not the cause of the pad sticking? Typically, caliper cast iron pistons are chrome plated. Over time, trapped water causes rust and the chrome plating on the piston starts to flake off and get rough. Likewise, the piston bore in the cast iron caliper gets pitted. The rough/chrome flaked surface, of the piston, prevents the piston from moving smoothly/retracting. Eventually, the rough surface of the piston starts to cut the o-ring seal in the caliper until oil leaks start.
Stainless steel pistons and bronze sleeving of the piston bores, in cast iron calipers, have been used in the past to eliminate this problem.
Best regards,
CJR
Old July 29th, 2018, 23:05
I don't know that the caliper isn't sticking. I did however weld/ grind the brake pad grooves, and greased the slides.
These are not the stock calipers so, thus far, though it may still be a possibility, the noise is gone.
If anything persists the caliper will be in check!
Sticking calipers, chirping brakes, dragging brakes? Here is the fix! xjtrailrider OEM Tech Discussion 3 July 31st, 2016 16:16
FRONT BRAKES STICKING bdavid OEM Tech Discussion 20 April 12th, 2016 13:51
Brakes sticking joejeep92 OEM Tech Discussion 6 April 13th, 2011 10:21
Front Brakes Sticking Badly loop OEM Tech Discussion 9 March 10th, 2005 01:46
Sticking front brakes... JohnBuuu OEM Tech Discussion 6 July 31st, 2003 09:38
