Old August 12th, 2019, 18:02
JeffW JeffW is offline
Engine Compartment Electrical burning smell
I was driving home today and the I smelled this electrical burning in the car. It was much stronger outside. I thought it was someone else. I parked in m drive way and about 15 minutes later I went on the porch and could smell the same thing very strongly from around the corner.
Something is going but I'm not sure where to start. I replaced the battery recently and my voltage sits around 12 at idle and never gets to 14. I was wondering if it cold be the alt going out? I took it for another drive this evening and it started to smell again so I turned off the A/C and when I got home I didn't smell it anymore. It doesn't smell like its coming from inside like I see with the other issues related to fan motor wiring.
Old August 13th, 2019, 05:56
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: Engine Compartment Electrical burning smell
How's the condition of the battery cables?
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old August 14th, 2019, 07:03
8Mud's Avatar
8Mud 8Mud is offline
I'd check the aux fan. If it is cooking off the motor will likely be very hot to the touch after running, I mean finger blistering hot.. If you can get close enough sniff the motor, if the windings are cooking it has a distinctive fried varnish smell. Don't sniff too much fried windings are supposed to be toxic.
Old August 14th, 2019, 18:56
It has to be something with the AC. I'm scared to turn it back on until I have time to look at this weekend but I haven't smelled any of it since I stopped using it. I found some posts with burning plugs from the resister fan plug that I'm going to look at. I did have the fan on position 1 when it was smoking.
Burning smell maybe? DSteveXJ OEM Tech Discussion 15 September 19th, 2010 14:07
burning smell 88xjchief OEM Tech Discussion 19 July 16th, 2007 07:15
Burning smell Zoro OEM Tech Discussion 1 April 12th, 2006 19:18
aw4 burning smell? ttms91xj Modified Tech Discussion 4 October 23rd, 2005 18:42
Burning Oil Smell BIGSLVRXJ OEM Tech Discussion 4 July 9th, 2005 16:58
