Old August 10th, 2019, 04:23
mpro1 mpro1 is offline
New Life For My 1990 Suggestions??
So, this is the second "re-furb". for my 1990 2dr sport. About 10-15 years ago I did did a complete suspension overhaul RE 3.5" w/ swing shackles, RE adjustable track bar (heim) shocks, tires, paint, all the usual engine mods etc. I have just completed some much needed repairs. New floor pans, cut n fold mod. 2x6 rockers, iro rear bumper, complete interior teardown and refurb. Dash, hvac, flat white paint, flat style flares. ECT.
Question recommendations.
Coil springs are cracked, CA bushings shot, leads were add a leaf. Setup for overlanding.
Do I get a complete suspension kit? LA or SA? or rebuild and replace worn out/ broken RE components?
Old August 11th, 2019, 05:54
Re: New Life For My 1990 Suggestions??
I guess the millenials have taken over this site. You know the ones that think the computer you plug into your car fixes it too..............
Old August 11th, 2019, 06:43
Sean778's Avatar
Sean778 Sean778 is offline
If it were my Jeep, I’d be more inclined to get some similar coils off of someone local who went for a bigger lift, and throw some new bushings in those short arms. As for the rear, I would get a whole new leaf pack with an appropriate amount of lift built into ‘er. I have those Iron Rock off-road leaf packs in back of mine, which I like. They are stiff, and I needed shackle relocation boxes to utilize these springs because they are a few inches longer than stock, but they are overbuilt, and would be good for someone who has added pounds of steel or has a lot of overlanding gear to haul.
Old August 11th, 2019, 07:06
RCP Phx RCP Phx is offline
Fix what needs to be fixed!
Coils usually don't crack. are you sure it's not the paint?
There is no "need" for LA's at that height. What control arms do you have?
Old August 13th, 2019, 06:57
denverd1's Avatar
denverd1 denverd1 is offline
stay short arms.
new coils
new full leaf packs
hit the trail
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
I now owe my GF my life 98_XJ_Classic Non-Tech / Off Topic 26 September 2nd, 2011 22:56
End of life. Kevin3151 SoCal Chapter 41 April 21st, 2010 11:45
best day of my life! 85xjproject OEM Tech Discussion 3 March 30th, 2008 03:43
Suggestions for water leak on a 1990???? cherokee4fun OEM Tech Discussion 10 January 9th, 2007 21:50
