C-MuRdaA
- Queens, NY
I installed YJ brake lines in the front of my XJ but I cannot get a hard pedal.
After installing the driver's side line I bled the brakes and all was fine. I installed the pass. side line and I cant get a hard pedal. I tried bleeding from the MC but that didnt work. I have installed a NEW MC but that didnt work either. I have a booster from a '97 ready to go in but before I rip everything apart again I want to see if I missed anything. I also installed new pads which I needed but before and after I installed them I had the same problem.
I have driven around my block and I can stop but there is only pressure at the bottom of the pedal and they are defintely not road worthy by any means.
TIA
TIA
