Old November 25th, 2012, 08:47
jeepdreamer's Avatar
jeepdreamer jeepdreamer is offline
RE long arms as a "kit"??
Anyone know if RE (or one of their vendors/distributors) sells just their long arm portion of their kit including the cross member? I see on their site where they sell both upper and lower arms for the kit but nothing about the cross member? Is it needed or can the LAs be run using the factory mounts (doubt it).?
Old November 25th, 2012, 09:36
Serious Offroad's Avatar
Serious Offroad Serious Offroad is offline
NAXJA Supporting Vendor
Re: RE long arms as a "kit"??
http://www.seriousoffroadproducts.co...RM-UPGRADE-KIT
Old November 25th, 2012, 11:34
Zoinks! That's a lot more than you LA kit! And it still has to be shipped. So much for trying to find a way to ship several boxes of a LA kit. Somewhere I must have pissed off the Jeep Gods. :I
Old November 25th, 2012, 11:37
I'll try to get you an exact freight quote for my upgrade kit tomorrow or Tuesday.
Old November 25th, 2012, 11:43
I'd really appreciate it. Maybe if it ships in several smaller boxes it won't be so bad. That damn itch to lift is killing me now. Thanks for the help sir!
Old November 25th, 2012, 11:48
2 boxes @ about 60lbs each.
Old November 25th, 2012, 12:01
If you can get a quote that would be awesome. I'm gonna need a pair of wide 5 on 4 1/2 wheel spacers too. And a pair of shackles.
Old November 25th, 2012, 22:57
Hadn't really thought about them but do you think I could run the stock control arms and use RE's drop brackets as a temp/less expensive alternative? I have no experience with these and as long as installing them doesn't effect a later upgrade to LAs, I could at least resell them. Ideas?
Old November 26th, 2012, 01:28
VAhasnoWAVES VAhasnoWAVES is offline
Stock arms are very weak. If your wheeling is to the point that you need long arms or drop brakets... You might want to look for a deal on arms in your local chapter, or just hold out for long arms.
Old November 26th, 2012, 02:49
Yup... I understand that the factor arms are weak. My intent is to build this with upgraded parts as I can. But for me the biggest hassle is being in Germany. Very few vendors will even ship stuff to a military APO address. And since that operates via USPS (worthless) the shipping is stupid expensive. It's looking like I will sit at between 4 1/2 to 5 inches of lift once the springs are added to the ACOS. I want to go with LAs for the improved ride and flex since I have to get arms anyway. But... due to the above mentioned reasons I am just trying to find a short term fix. Note* This XJ will see ZERO off roading until I get it back to the states. Nada. All it is for is to scoot me around the base here and give me a platform to bolt/store a bunch of my junk to come back home with that won't fit in my house hold goods.
Old November 26th, 2012, 09:03
There a a few vendors out there offering quality systems cheaper than RE. I'm partial to Clayton.
Have you considered having a friend stateside mail it to you?
Another option would be building... Have you considered just buying heims and fabbings something up? Don't most bases have like, a hobby shop you can use?
Old November 26th, 2012, 09:31
Yes, thankfully there are a few that have been helping me...Serious off road and JCR have been tops! SOR is where I have gotten most of my stuff so far. I even hope to run his long arm conversion but it sounds like it will be to costly to ship here due to its weight..maybe. And dollars for doughnuts, I think the SOR kit is a quality piece comparable to Clayton and RE and a few others...just not as expensive.
The friend as a middle man thing is just added time and cost and I can't really afford either in abundance since I'll be leaving so soon.
I only briefly pondered the idea of making my own LA kit. Yes, I probably could but in this case buying makes far more sense. If I ordered all the stuff and something got lost in the mail or I cut something wrong and had to reorder I'd be royally screwed. Maybe if I can't get it done one way and have to head home with it a low rider I will give it a shot. Not a lot of local support here when it comes to fabrication and I haven't found DOM tubing anywhere near me.
And your correct... we do have auto skills centers on (most) military bases. The one where I am at closes about the time I get off work and isn't open on Sundays. That leaves me basically just Sat to work on any project. And believe me... I am already a fixture there from working EVERY free day I have on one of my Jeeps.
Old November 26th, 2012, 10:27
Was just throwing some ideas out there, looks like you've thought of everything. Lol.
Hope ya figure something out.
Old November 26th, 2012, 10:51
About the only thing I've figured out is that I need to win the lottery and build a 50K sq foot garage! lol! Thanks for your suggestions.... something will work it out somehow. I've been kicking the idea of just running the ACOS and some sort of Bastard pack to see if I can gain enough to simply clear the tires I have. As I mentioned, this thing won't be getting wheeled before I can get it done right like I want it. But I'm just not sure how else to squeeze in a set of 33x9.50ATs for the boat ride home.
Old November 26th, 2012, 12:45
premoxj's Avatar
premoxj premoxj is offline
yes, you can off the www.4wd.com website. That's what i did. i bought the LA upgrade kit, their springs, bilstiens and used my existing trackbar. The LA upgrade is fairly inexpensive as opposed to the whole kit.
"CUSTOM 8” LIFT W/RUSTY’S LONG TRAVEL ARMS " 89cherokeexj SoCal Chapter 18 June 2nd, 2010 22:44
RE4.5" to long arms nonnie Modified Tech Discussion 2 April 17th, 2006 12:49
88xj, 6.5" RE lift,8.8,35"s Long arms xjridingtough For Sale: Private Party Only. XJ ITEMS ONLY 4 January 19th, 2005 16:56
Xj with 7" lift long arms and 35's joshluther For Sale: Private Party Only. XJ ITEMS ONLY 0 August 4th, 2003 21:09
