NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
Inspect the drivers door wire harness at and near the rubber boot for chafed wire insulation, broken wires, and failed wire splices. Since the doors have positive 12 volts at all times for the door locks, any short circuits in the wires or short circuits to ground can introduce 12 volts positive into other wire circuits.
Perform an instrument cluster test. Consider removing the instrument cluster and inspecting/cleaning the connector pins and plugs on the backside.
Check the connector at the back of the gauge cluster. Sometimes merely pressing
moderately hard on the gauge cluster with your thumbs will reconnect things, but
be careful not to crack the clear plastic lens. Otherwise, you'll have to remove the
cluster and clean the connector and put it back.
Also, check the ground wires on the passenger side of the engine block, to the left of
the oil check dipstick tube. Those wires are short and taught and, over the years,
engine vibes will often fatigue the wires and cause them to break or fall off of the
ring connector end.
