Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
  #16
Old November 8th, 2019, 09:33
Ralph77 Ralph77 is offline
Re: 2000/4.6/Screamin-Demon/Holley MSD
This the bypass mode thing just when using the MSD?
the Ksuspenison kit comes with a Spectra C595.
It lists all these at RockAuto for the application.
CHRYSLER GRAND VOYAGER 2001-2002
CHRYSLER PACIFICA 2005-2008
CHRYSLER TOWN & COUNTRY 2001-2010
CHRYSLER VOYAGER 2001-2008
DODGE CARAVAN 2001-2007
DODGE GRAND CARAVAN 2001-2010
DODGE RAM 1500 PICKUP 2004-2006
DODGE RAM 2500 PICKUP 1997-2003
DODGE RAM 3500 PICKUP 1997-2003
DODGE VIPER 1997-2006
JEEP WRANGLER 2007-2011
VOLKSWAGEN ROUTAN 2009-2010
Here is the thing. If you look up a Grand Voyager Mopar coil you and look up the 6 coil part of a Viper/Ram V10 Mopar coil you get to different part numbers.
If you check out the Spectra coil on other sites they don't list the Viper or the Ram.
https://www.carid.com/spectra-premiu...mpn-c-595.html
Scroll down the page to see the applications.
So I wonder what the deal is. You can use it, it will work apparently, but are you getting all the performance out of the coil that you can?
Old November 8th, 2019, 09:34
So the Screamin' Demon Coil might not be a suitable for an '00?
Old November 8th, 2019, 09:40
RCP Phx RCP Phx is offline
The "bypass" is a option with the MSD kit in case goes wrong "it" you can remove "it" from the system going back to stock.
In theory the Dodge coils (00-01 XJ,Viper, and anything running the 3.8 motor the coils draw 12amps, the Screamin Demon coil draws 16amps.
Old November 8th, 2019, 09:47
So now I am back to being confused.
Guessing that is not a good thing.
Old November 8th, 2019, 09:55
From the other thread..
The other option is to try it with another new PCM(which I have), my existing PCM is a "custom tuned" one so I don't want to damage it.
I should add that I've already been thru one PCM due to wire harness meltdown and do not want to go thru that again. It was a major PITA to repair the harness.
I think your missing that the MSD supplies it's own power and only uses the PCM for "trigger".
Old November 8th, 2019, 10:01
In other words if you have Screamin Demon coil in your MSD system under "bypass" mode your PCM is seeing full coil load on it's own!
Old November 9th, 2019, 07:19
I received my connectors(one wrong so I have to re-order, and my chromoly. This morning it's time to get cutting/drilling.
Old November 9th, 2019, 17:19
I made pretty good progress today, I'll finish up tomorrow.
Old November 12th, 2019, 14:17
I finally finished the holes and got it in the brake to 50*.
Old November 15th, 2019, 14:32
I got the bracket done today, will install tomorrow after the paint dries.
Old November 16th, 2019, 10:56
It's a shoehorn but it's in! Next will be wiring.
Old November 16th, 2019, 12:38
The concept here is to make one clean harness out of all this......
Old November 16th, 2019, 15:54
The K Fab wiring harness is a bit of a joke ,there are splices inside indicating they just use some factory tails and add on to them.
Old November 18th, 2019, 16:18
I posted this in the other thread, I'm just waiting on a 1-1/2" heat before I can assemble the Deutch connector.
Old November 22nd, 2019, 08:36
Ok, I finally finished the harness! Today I will install and test it(notice the bypass/test plug), if all goes well tomorrow I will install the spark plugs and coil and plug the MSD in!
Rate This Thread:
Anyone w/ a '00-01 and a Screamin Demon coil? RCP Phx Modified Tech Discussion 9 November 2nd, 2019 07:00
IM GONNA START SCREAMIN SOON!!! jmeti000 OEM Tech Discussion 15 January 8th, 2009 06:30
screamin deal on axles. I think? noobie2Cherokee Modified Tech Discussion 4 November 3rd, 2006 14:43
Screamin' Demon drifting_home Modified Tech Discussion 3 May 5th, 2005 17:24
3.4L XJ...holley or not? myjeepsbigger Modified Tech Discussion 9 September 24th, 2003 20:55
